Documentation forDatabase Performance Analyzer
DPA license types
License requirements depend on the type of SolarWinds DPA deployment:
  • If you deploy DPA on a self-managed server or in the Azure Marketplace, you must have a license for each monitored database instance.
  • If you deploy DPA in the Amazon Web Services (AWS) Marketplace, the AWS Marketplace Metering Service is used to calculate DPA charges.
See the following sections for details:
License types
You can monitor database instances without allocating licenses during the 14-day trial period. After the trial period, you must allocate a license for each database instance that you want to monitor.
Subscription licenses are currently available for DPA. Subscription licenses have an expiration date. When the subscription is current, users have access to all DPA functionality and they are entitled to technical support and upgrades.
If a subscription license allocated to a database instance is not renewed before it expires, historical data is available for the instance, but DPA does not continue to collect new data.
Some DPA features are available only for subscription licenses.
The following license types are available as subscription licenses:
The following license types are available as subscription licenses in DPA 2024.3 and earlier:
Perpetual licenses were available for earlier versions of DPA. They could be used to monitor database instances indefinitely, but annual maintenance fees were required. The following license types were available as perpetual licenses:
Database coverage by license type
indicates that the license can be used to monitor the database instance.
indicates that the license can be used, but it is a higher-level license than required.
Database type or environment DBSH DBSHDS Cat 1 Cat 2 Azure SQL Database VM Option
SQL Server
Amazon RDS for SQL Server
Azure SQL Managed Instance
Google Cloud SQL for SQL Server
Azure SQL Database
Oracle Enterprise Edition
Oracle Standard, Free, and Express Editions
Amazon RDS for Oracle
SAP ASE (Sybase)
SAP ASE (Sybase) Express Edition
IBM Db2
IBM Db2 Express Edition
MySQL
Percona MySQL
Amazon RDS for MySQL
Amazon Aurora for MySQL-compatible
Azure Database for MySQL
Google Cloud SQL for MySQL
MariaDB
Amazon RDS for MariaDB
Azure Database for MariaDB
PostgreSQL
Amazon RDS for PostgreSQL
Amazon Aurora for PostgreSQL-compatible
Azure Database for PostgreSQL
Google Cloud SQL for PostgreSQL
EDB Postgres
Amazon RDS for PostgreSQL EDB
SAP HANA Platform and Express Editions
SAP HANA Cloud
VM metrics
Database Self-Hosted licenses
SolarWinds offers two self-hosted database monitoring products: SolarWinds DPA and SolarWinds SQL Sentry. The following license types can be used with either product. These license types are subscription only:
  • Database Self-Hosted (DBSH) licenses can monitor any edition of any supported database type.
    If a database instance runs on a virtual machine (VM), the DBSH license also collects performance metrics from the VM and the physical host on which the database instance runs. (An additional VM Option license is not required.) This information is displayed in the Virtualization view.
  • Database Self-Hosted DBaaS (DBSHDS) licenses can monitor supported database targets running in a DBaaS environment, such as Azure SQL Database.
Database Self-Hosted (DBSH) and Database Self-Hosted DBaaS (DBSHDS) license keys are available with DPA 2024.4 and later.
Some features, such as AI query assist, are available only for database instances that use a DBSH or DBSHDS license.
The ability to use these licenses with either DPA or SQL Sentry gives you flexibility. You can use licenses from the same license key across both products. For example, if you purchase a license key with 10 licenses, you can use 5 of the licenses to monitor instances with DPA, and use the other 5 to monitor instances with SQL Sentry.
Category 1, Category 2, Azure SQL Database, and VM Option licenses
The following classic license types were available as perpetual licenses. In DPA 2024.3 and earlier, they were also available as subscription licenses.
  • For Category 1 and Category 2 licenses, the license type specifies what database editions the license is authorized to monitor. The section Database coverage by license type indicates which database instances each DPA license type can monitor.
    Some database types require a Category 1 license, while others can be monitored with either a Category 1 or Category 2 license. For example, an Oracle Enterprise Edition instance requires a Category 1 license. But any other Oracle instance can be monitored with either a Category 1 or Category 2 license.
    No additional functionality is provided by a Category 1 or Category 2 license. The only difference between Category 1 and Category 2 licenses is the types of database instances they can monitor.
  • Azure SQL Database licenses can be used to monitor Azure SQL Database.
  • VM Option licenses can be applied in addition to a Category 1 or Category 2 license to monitor the virtual infrastructure hosting a database instance. When you apply a VM Option license, DPA collects performance metrics from the VM and the physical host on which the database instance runs. This information is displayed in the Virtualization view.
All licenses are floating
You can register more instances than you have licenses for. On the license allocation page, assign the licenses to the instances you want to monitor.
DPA does not collect data from registered database instances that are not licensed. However, you can view previously collected data on those database instances.
Clustered environments
For information about registering SQL Server AGs and Oracle RACs, see Registration and licensing options for clustered environments.
When you deploy a DPA server from the AWS Marketplace, DPA uses the AWS Marketplace Metering Service to calculate charges. You can register database instances and immediately begin monitoring them without purchasing or allocating DPA licenses. DPA charges are based on the number of database instances you monitor each hour, and the charges are billed through Amazon. See the AWS Marketplace for details and pricing.
With the AWS Marketplace Metering Service, you can monitor any supported database type (like the Category 1 license). However, you cannot access the VM-related information that is available with a VM Option license.
If you want to use DPA licenses in the Amazon cloud, you can deploy an EC2 instance, install DPA, and apply your licenses. You cannot use both DPA licenses and the AWS Marketplace Metering Service on a single DPA server.
Learn more
For more information about purchasing and allocating licenses, see:
