Documentation forDatabase Performance Analyzer
DPA alert categories and types
DPA provides a wide range of alert types in four categories.
DPA provides the following alert categories:
  • Wait Time alerts are triggered when wait time exceeds a user-defined threshold, or when wait time is much higher than expected (an anomaly).
  • Resources alerts are triggered when a resource metric, such as CPU or memory usage, exceeds its threshold.
  • Administrative alerts are used to monitor the health of the database system.
  • Custom alerts are user-defined SQL statements or stored procedures that are run against the monitored database or the DPA repository.
DPA Wait Time alert types
For Wait Time alerts, DPA evaluates the amount of wait time that occurred during each alert execution interval. An alert is triggered if the wait time during an interval exceeds the specified threshold.
To create a Wait Time alert, see Configure a DPA Wait Time alert.
Alert type DB type Description
Database Instance Wait Time Anomaly All Alerts you when the wait time of an instance was abnormally high during the most recently completed hour. The wait time status is calculated at the top of each hour using the DPA anomaly detection algorithm.
Total Database Instance Wait Time All Alerts you when the total wait time for an entire database instance exceeds the threshold.
Total SQL Wait Time for a Single SQL All Alerts you when the total execution time for the specified SQL statement exceeds the threshold.
Average Wait Time for a Single SQL All Alerts you when the average execution time for the specified SQL statement exceeds the threshold.
Total SQL Wait Time for Single Wait All Alerts you when the total wait time for the specified wait type or event exceeds the threshold.
Total SQL Wait Time - Program All Alerts you when the total execution time for SQL statements executed by the specified program or application exceeds the threshold.
Total SQL Wait Time - Database User All Alerts you when the total execution time for SQL statements executed by the specified database user exceeds the threshold.
Total SQL Wait Time - O/S User Oracle Alerts you when the total execution time for SQL statements executed by the specified operating system (OS) user exceeds the threshold.
Total SQL Wait Time - Machine All Alerts you when the total execution time for SQL statements executed on the specified computer exceeds the threshold.
Total SQL Wait Time - Database All except Oracle Alerts you when the total execution time for the specified database in an instance exceeds the threshold.
Total SQL Wait Time - Custom for Oracle Oracle
Alerts you when the total wait time for any combination of the following exceeds the threshold:
  • Specified wait type or event
  • Specified SQL statement
  • SQL statements executed by the specified program or application
  • SQL statements executed by the specified database user
  • SQL statements executed by the specified OS user
  • SQL statements executed on the specified computer
Total SQL Wait Time - Custom for SQL Server/Azure SQL MI/Sybase SQL Server, ASMI, Sybase
  • Specified database in an instance
Total SQL Wait Time - Custom for Azure SQL Database Azure SQL Database
Total SQL Wait Time - Custom for MySQL/MariaDB MySQL, MariaDB
  • Wait events associated with the specified wait instrument
  • SQL statements that perform the specified operation, such as select or fetch
Total SQL Wait Time - Custom for Db2 Db2
  • Specified database (the Database field is ignored when a single database is being monitored)
Total SQL Wait Time - Custom for PostgreSQL PostgreSQL
RAC Overhead Wait Time Oracle Alerts you when the total wait time for RAC events exceeds the threshold.
Total Blocking Wait Time Oracle, SQL Server, Azure SQL DB, ASMI, Sybase, MySQL, PostgreSQL Alerts you when the amount of time that sessions waited due to blocking exceeds the threshold. Wait time due to blocking is shown on the Blocking tab.
DPA Resources alert types
For Resources alerts, DPA looks at the metric values collected during each execution interval and applies the calculation that you specify in the alert definition (percentage, average, median, maximum, or minimum). An alert is triggered if the resulting calculated value exceeds the specified threshold.
Resource alert types apply to any database type.
To create a Resources alert, see Configure a DPA Resources alert.
Single Resource Metric All Alerts you if the calculated value for a specific resource metric exceeds the threshold.
All Metrics in a Category All Alerts you if the calculated value for all resource metrics a category exceeds the threshold.
DPA Administrative alert types
Alerts in the Administrative category are triggered when DPA detects certain conditions or events.
To create an Administrative alert, see Configure a DPA Administrative alert.
Database Instance Availability All
Alerts you if a monitored database instance is not available. DPA determines availability by attempting to connect to the instance.
By default, this alert is triggered the first time DPA is unable to connect to the monitored instance (the default number of retries is 0). If you would like the alert to be triggered only after multiple consecutive connection attempts fail, set the advanced configuration option ALERT_CONNECTION_ATTEMPTS.
Database Freespace SQL Server, Azure SQL DB, ASMI, Sybase, Db2 Alerts you if the percentage of free space in any database in the instance (or in the single database for Azure SQL databases) falls below the threshold.
Database Instance Parameter Changes All except MySQL Alerts you if any database instance parameter settings are changed.
Tablespace Freespace Oracle, Db2 Alerts you if the percentage of free space in any tablespace in the monitored instance falls below the threshold. For Db2, only database-managed tablespaces (DMS) are evaluated.
Transaction Log Freespace SQL Server, ASMI, Sybase, Db2 Alerts you if the percentage of free space in the transaction log of any database in the instance falls below the threshold.
Oracle PDB Move Oracle Alerts you when a monitored PDB database instance is moved to or from a CDB container.
Oracle PDB Database Instance Availability Oracle Alerts you if a monitored PDB database instance is not available. DPA determines availability by attempting to connect to the instance.
Oracle Alert Log Entries Oracle Alerts you when the alert log contains more than the minimum number of occurrences of the specified string. DPA searches for the specified string in the alert log (from the x$dbgalertext table) and returns all unique matching entries and the count of each entry. The thresholds for each alert level specify the minimum and maximum number of occurrences for that level.
Oracle Long Running Transaction Oracle Alerts you when a transaction runs for more than the number of seconds specified by the threshold.
Oracle Percent Redo Logs Unarchived Oracle Alerts you when the percentage of unarchived redo logs exceeds the threshold.
Oracle Redo Log Switching Frequency Oracle Alerts you if the number of redo log switches during an execution interval exceeds the threshold. To avoid alerts during periods when frequent log switches are expected, you can specify a time range to include or exclude.
Oracle Session Limit Oracle Alerts you if the percentage of active sessions exceeds the threshold. To determine the percentage of active sessions, DPA compares the number of active sessions to the maximum number of sessions. The maximum number of sessions is configured in the v$parameter 'sessions' row.
Oracle Stale Statistics Oracle
Alerts you if tables or indexes have stale or empty statistics. You can specify schemas to include or exclude. The alert notification lists all tables and indexes (in included schemas) that have stale or empty statistics.
To avoid repetitive alerts, SolarWinds recommends that you increase the execution interval for this alert to at least one day.
Oracle Archiver Errors Oracle Alerts you if the archiver process receives an error while trying to archive a redo log or if the online log files are not being archived. If the problem is not resolved quickly, the database stops executing transactions. This alert is typically triggered when the destination device is out of space to store the redo log file.
Windows Service Not Running - SQL Server SQL Server Alerts you if the specified Windows service is not running in the selected SQL Server database instances.
SQL Server Abnormal Mirroring Status SQL Server Alerts you if the SQL Server mirroring status is anything other than Synchronized.
SQL Server Availability Group Failover SQL Server Alerts you if an availability group has failed over from one instance to another.
SQL Server Availability Group Status Change SQL Server Alerts you if an availability group has had a change in status to Partially Healthy or Not Healthy. An Alert Level of High indicates Not Healthy and Medium indicates Partially Healthy.
SQL Server Deadlocks SQL Server, ASMI Alerts you if the number of deadlocks that occurred on an instance exceeds the threshold.
SQL Server Error Log Alert SQL Server, ASMI Alerts you if error logs contain a specified string or pair of strings.
SQL Server/Azure SQL Ineffective Statistics SQL Server, ASMI, Azure SQL DB
Alerts you if indexes have ineffective statistics. It uses criteria such as time since last stats update, percent of rows changed, and table size. You can specify database to include or exclude. The alert notification lists all indexes (in included databases) with ineffective statistics.
SQL Server Job Failure SQL Server, ASMI Alerts you if a job fails. The alert notification reports all jobs that failed since the last time this alert was executed.
SQL Server Backup Frequency SQL Server Alerts you if the number of days since the last backup of the specified type (full, differential, or transaction log) exceeds the threshold.
SQL Server Recovery Backup Assets Size SQL Server Alerts you if the size of all backup assets required to recover a database exceeds the threshold.
SQL Server Backup Jobs Running SQL Server Alerts you if the number of currently running backup jobs for a specified database instance exceeds the threshold.
SQL Server Backup Time Allotted SQL Server Alerts you if the time required to complete the last backup of the specified type (full, differential, or transaction log) exceeds the threshold.
SQL Server Log has Many Virtual Logs SQL Server, ASMI Alerts you if the number of Virtual Logs in any database exceeds the threshold. To limit the result set and reduce the required DPA Repository space, set the Minimum number of virtual logs.
SQL Server Long Running Jobs SQL Server, ASMI Alerts you if any jobs (in SQL Agent) are running longer than two standard deviations from the mean execution time based on previous execution times.
DPA Database Instance Monitor Errors All Alerts you if any errors occurred while monitoring a database instance.
DPA Resource Collection Errors All Alerts you if any errors occurred while collecting resource data for a database instance.
MySQL/MariaDB Temporary Tables Creation Rate MySQL, MariaDB Alerts you if the number of temporary tables created per second exceeds the threshold.
MySQL/MariaDB Temporary Tables on Disk Creation Rate MySQL, MariaDB Alerts you if the number of temporary tables created on disk per second exceeds the threshold.
MySQL/MariaDB Schema Freespace MySQL, MariaDB Alerts you if the percentage of free space in any schema exceeds the threshold. Free space is occupied by the MySQL database, but it is not being used.
MySQL/MariaDB Table Freespace MySQL, MariaDB Alerts you if the percentage of free space in any table exceeds the threshold. Free space is occupied by the MySQL database table, but it is not being used.
MySQL/MariaDB Oversized Index MySQL, MariaDB Alerts you if any table has defined indexes that occupy more overall space than the percentage specified as the threshold.
MySQL/MariaDB Tables Missing Primary Key MySQL, MariaDB This alert determines if any of the MySQL tables does not have PK defined
MySQL/MariaDB Latest Deadlock Alert MySQL, MariaDB Alerts you if there is an unseen deadlock in a database.
MySQL/MariaDB InnoDB Buffer Pool Utilization Alert MySQL, MariaDB Alerts you if the percentage of free buffer pages is below the threshold. Data reflects activity against tables managed by the InnoDB (or an InnoDB-based) storage engine.
MySQL/MariaDB InnoDB Log File Size Alert MySQL, MariaDB Alerts you if the REDO log file size is below the threshold. Data reflects activity against tables managed by the InnoDB (or an InnoDB-based) storage engine.
MySQL/MariaDB File Sorts on Disk Alert MySQL, MariaDB Alerts you if a database instance frequently sorts to disk instead of performing the sort in memory. The alert is triggered if the number of disk sorts during an execution interval exceeds the threshold.
MySQL/MariaDB Replication Seconds Behind Master Alert MySQL, MariaDB Alerts you if the replication (slave) instance is more than the specified number of seconds behind the master.
MySQL/MariaDB Replication Threads Availability Alert MySQL, MariaDB Alerts you if the replication (slave) MySQL database threads (I/O and slave) are unavailable.
MySQL/MariaDB Redundant Indexes Alert MySQL, MariaDB Alerts you if any tables in a database instance contain redundant indexes.
MySQL/MariaDB Duplicate Indexes Alert MySQL, MariaDB Alerts you if any tables in a database instance contain duplicate indexes.
PostgreSQL Autovacuum Status PostgreSQL Alerts you if the autovacuum process is OFF. The autovacuum process helps prevent table bloat.
PostgreSQL Track Counts Status PostgreSQL Alerts you if the track_counts setting is OFF. The track_counts setting must be ON to allow PostgreSQL to collect statistics on database activity. The autovacuum process requires these statistics.
PostgreSQL Track Activities Status PostgreSQL Alerts you if the track_activities setting is OFF. The track_activities setting enables tracking of currently executing SQL statements, and it must be ON to allow DPA to monitor the database instance.
PostgreSQL Last Analyze PostgreSQL
This alert reports the number of hours since the last time each table was analyzed (either manually or automatically). If a table was never analyzed, 100000 hours is reported. Table analysis updates a table’s statistics, which are used to determine efficient query plans, resulting in faster queries. Other benefits of analyzing include better dead tuple vacuuming and better index rebuild decisions.
PostgreSQL Last Auto Analyze PostgreSQL
This alert reports the number of hours since the last time each table was auto-analyzed. If a table was never auto-analyzed, 100000 hours is reported. Autoanalyze is a process that updates table statistics, and is triggered based on the number of modified rows (inserts, updates, or deletions). Autoanalyze is enabled by default in a PostgreSQL instance. Accurate table statistics are important because they are used to determine efficient query plans, resulting in faster queries. Other benefits of analyzing include better dead tuple vacuuming and better index rebuild decisions.
PostgreSQL Last Vacuum PostgreSQL
This alert reports on the number of hours since the last time each table was vacuumed (either manually or automatically). If a table was never vacuumed, 100000 hours is reported. Autovacuum is enabled by default in a PostgreSQL instance, and is triggered by a high number of dead tuples in any given table. Vacuuming can also be triggered manually by using the VACUUM command. Vacuuming is an essential maintenance task that ensures the health and performance of the database by removing dead tuples. Dead tuples are old versions of table rows that remain until a vacuum process removes them. Without vacuuming, dead tuple space accumulates, leading to increased disk usage and slower performance.
PostgreSQL Last AutoVacuum PostgreSQL
This alert reports on the number of hours since the last time each table was auto-vacuumed. If a table was never auto-vacuumed, 100000 hours is reported. Autovacuum is enabled by default in a PostgreSQL instance, and is triggered by a high number of dead tuples in any given table. Vacuuming is an essential maintenance task that ensures the health and performance of the database by removing dead tuples. Dead tuples are old versions of table rows that remain until a vacuum process removes them. Without vacuuming, dead tuple space accumulates, leading to increased disk usage and slower performance.
PostgreSQL Long Running Vacuum PostgreSQL
This alert reports on PostgreSQL vacuum processes that have been running for longer than the specified threshold. It considers both manual and automatic vacuum processes.
PostgreSQL Long Running Query PostgreSQL
This alert reports on queries that have been running in the PostgreSQL instance for longer than the specified threshold. It excludes queries run from system databases and from system processes.
PostgreSQL Dead Tuple PostgreSQL
This alert monitors the row count or percentage of dead tuples in user tables or in user and system tables. A high percentage can indicate that the PostgreSQL vacuuming process is not healthy. A dead tuple is an outdated version of a row that was updated or deleted. It is no longer needed by any transaction, and the vacuuming process should remove it so the space can be used for new rows.
You can specify that the results include dead tuples for individual tables or each database. You can also include or exclude specific databases, schemas, and tables.
PostgreSQL Percent Idle in Transaction Connections PostgreSQL
This alert reports the percentage of each database’s open connections that have a status of “idle in transaction” relative to the maximum number of connections allowed by the PostgreSQL instance. Connections in this status indicate that a transaction has been started but is currently idle. Such transactions could hold locks for extended periods of time, preventing other transactions from accessing the locked resources, and therefore affecting their performance. They can also affect memory consumption, impact vacuum processes, and affect environments that use connection pools.
PostgreSQL Total Connections PostgreSQL
Each PostgreSQL instance has a maximum number of connections (max_connections in pg_settings). This alert warns you when a high percentage of the available connections are in use. It includes connections in all states.
PostgreSQL User Role Expiry PostgreSQL
This alert monitors PostgreSQL user role expirations, triggering a notification when a role has expired or is set to expire within the specified number of days. Negative values indicate that the role has already expired, while positive values indicate roles that are still active. Roles with an expiration of infinity are treated as expiring in 10 years, and roles with an expiration of -infinity are treated as having expired 10 years ago.
PostgreSQL Total Table Bloat in Database PostgreSQL This alert warns you if the percentage of bloat (unused space that was not reclaimed) exceeds a threshold.
PostgreSQL Collect Database Size PostgreSQL This alert collects the size of each database in a PostgreSQL cluster. This alert is never triggered. The collected data is used as input for the PostgreSQL Database/Table Percentage Growth alert.
PostgreSQL Collect Relation Table Size PostgreSQL This alert collects the size of each relation (table) in a PostgreSQL cluster. This alert is never triggered. The collected data is used as input for the PostgreSQL Database/Table Percentage Growth alert.
PostgreSQL Database/Table Percentage Growth PostgreSQL This alert warns you if the size of the database or the size of all relations increase by more than the specified percentage during an execution interval. Depending on which size you are monitoring, the PostgreSQL Collect Database Size alert or the PostgreSQL Collect Relation (Table) Size alert must also be configured.
DPA Custom alert types
Custom alerts are triggered based on the value(s) returned by a user-defined SQL statement or stored procedure. Custom alerts apply to all database types.
To create a Custom alert, see Configure a DPA Custom alert.
Custom SQL Alert - Single Numeric Return All Executes a user-defined SQL statement that returns a single numeric value. The alert is triggered if the value exceeds a threshold.
Custom SQL Alert - Multiple Numeric Return All Executes a user-defined SQL statement that returns one or more rows with a string in the first column and a numeric value in the second column. The alert is triggered if any numeric value exceeds a threshold.
Custom SQL Alert - Single Boolean Return All Executes a user-defined SQL statement that returns a single string value of TRUE or FALSE (not case-sensitive). The alert is triggered if the SQL statement returns TRUE.
Custom SQL Alert - Single Alert Status Return All Executes a user-defined SQL statement that returns a single string value that specifies the alert status. Valid values are NORMAL, INFO, LOW, MEDIUM, and HIGH (not case-sensitive).
Custom Procedure Alert - Single Numeric Return All Executes a user-defined stored procedure that returns a single numeric value. The alert is triggered if the value exceeds a threshold.
Custom Procedure Alert - Single Boolean Return All Executes a user-defined stored procedure that returns a single string value of TRUE or FALSE (not case-sensitive). The alert is triggered if the stored procedure returns TRUE.
Custom Procedure Alert - Single Alert Status Return All Executes a user-defined stored procedure that returns a single string value that specifies the alert status. Valid values are NORMAL, INFO, LOW, MEDIUM, and HIGH (not case-sensitive).
