Documentation forStorage Resource Monitor
Thin Storage Pools (by Capacity)
When displayed on a summary dashboard, this widget provides a lists of all thin Storage Pools being monitored in the storage environment.
When displayed on a storage object details page, this widget provides a lists of all thin Storage Pools associated with the object.
A thin, or virtual, storage pool is a representation of a storage area and not tied to any physical storage allocation.
Storage pools can be sorted by any column.
You can search the list of storage pool displayed by entering any part of the pool name in the search box.
For each thin storage pool, the status and name, total size, and provisioned capacity, subscribed capacity and over-subscribed capacity are displayed.
Projected File Run Out shows the estimated time remaining before the volume runs out of space. Statistics are gathered from the last 3 months and are projected to a linear prediction that calculates the date when Run-Out will be reached.
Click Edit to:
  • Change the title and subtitle.
  • Specify the number of pools displayed.
