Documentation forHybrid Cloud Observability Essentialsand Storage Resource Monitor
Unmanage and remanage an array in SRM
If you need to stop monitoring a storage array:
  1. Navigate to the array Detail page using the All Storage Objects widget.
  2. Click Unmanage on the Management widget.
    The Unmanage window opens.
  3. Enter the start and end date and times of the period for which you want to suspend monitoring.
    To unmanage immediately, click OK. This will unmanage the array for 24 hours or until you remanage the array.
  4. To restart monitoring an array, repeat this procedure, but click Remanage on the array management widget.
To unmanage multiple arrays, use the Manage Storage Objects page:
  1. Click Settings > All Settings.
  2. Click Manage Storage Objects.
  3. Select the arrays that you want to unmanage and click Unmanage.
  4. Enter the start and end date and times of the period for which you want to suspend monitoring.
  5. To restart monitoring an array, repeat this procedure, but click Remanage when you have selected the objects.
