Storage Objects by Capacity Risk
This widget displays all storage objects currently being monitored by SRM, listed by capacity risk. Object already at full capacity are shown first, followed by devices approaching full capacity.
Spark charts show usage over the last seven days for each object. Move the cursor over the line to show amount of storage used in that period, The icon and percentage after the spark chart show how this has increased or decreased between the last two pollings.
The estimates for when warning (90% used), critical (95% used) and capacity (100% used) thresholds will be met are calculated using data from recent pollings. If this data is too erratic, "Passed" is displayed. If these are presently met or exceeded, the data is highlighted in yellow, red or black and "Now" displayed.
Click Edit to:
- Change the title and subtitle.
- Number of objects displayed.
- Filter objects using simple SQL queries. For example:
TYPE = 'LUN'
to list only LUNs.ARRAY LIKE 'lan-netapp%'
to list only objects with an array name starting with 'lan-netapp'.
