Documentation forHybrid Cloud Observability Essentialsand Storage Resource Monitor
Top 10 Storage Controller Ports by Total IOPS
This widget shows a graph comparing the performance over the selected time period for the top performing Storage Controller Ports attached to the current storage controller with the highest total IOPS. By default the top ten performing Storage Controller Ports are displayed.
You can hide any of the Storage Controller Ports for clarity.
You can display performance data for the last hour, the last 12 hours, or the last 24 hours using the Zoom buttons, or set the start and end points from the historical data selection to select a custom period, by setting the start and end points from the historical data selection shown below the charts.
Click Edit to:
  • Change the title and subtitle of the widget.
  • Change the maximum number of Storage Controller Ports to be displayed.
  • Change the default zoom range, amount of historical data to load, and sample interval.
  • Add a chart title and subtitle.
