Documentation forStorage Resource Monitor
Monitor hardware health for SRM
SRM offers hardware health monitoring for selected arrays, giving you immediate insight into hardware issues in your storage environment. Monitoring hardware health on storage arrays gives access to the status and values of onboard sensors. In addition to displaying this data on the Hardware Health page for the array, you can set thresholds to use in monitoring and alerts.
Hardware health data is collected when the storage array is polled for statistics/performance data. By default this is every 15 minutes, although this can be amended for individual devices.
SRM hardware health metrics
The hardware health metrics available for monitoring an array depend on the vendor and model.
This table assumes that the latest firmware is installed on the array. Status monitoring may vary on older versions.
The table shows only sensors that provide statuses; some sensors, such as SpCards and Storage Controllers, are present in hardware health but they are only used to aggregate sensors.
Hardware health data is available for the following arrays and sensors:
Array Sensors
Dell Compellent Cache cards, Disks, Fans (value), FC ports, iSCSI ports, I/O modules, Power supplies, SAS ports, Temperature (value), Voltage (value)
Dell EqualLogic PS Series
Fans (value), Temperature (value), Power supplies
Dell PowerScale/EMC Isilon Batteries, Disks, Fans (value), Ethernet ports, FC ports, Power supplies, Temperature (value)
Dell PowerStore Q Enclosure, node, power supply, I/O module, adapter, SFP (port), battery, memory, disk, CMC, fan, drive
Dell PowerStore T Enclosure, node, power supply, I/O module, adapter, SFP (port), battery, memory, disk, CMC, fan, drive
EMC Data Domain
Batteries (value), Disk temperature (value), Fans, Power supplies, SCSI Target Ports, Temperature (value)
EMC Isilon/Dell PowerScale Batteries, Disks, Fans (value), Ethernet ports, FC ports, Power supplies, Temperature (value)
EMC Unity Batteries, Disks, Ethernet ports, Fans, Fiber Channel ports, Link control cards, Memory, Power consumption (value), Power supplies, SAS ports, SSDs, Temperature (value)
EMC VMAX3 and VMAX All Flash Family (HYPERMAX OS) Batteries, Fans, Management Controllers, I/O Modules Memory, Ports, Power Supplies
EMC VNX NAS Gateway / Celerra
Batteries, Fans, Management Controllers, Ports
EMC VNX / CLARiiON
Batteries, Disks, Fans, Management Controllers, Ports, Power Supplies
EMC Symmetrix VMAX / VMAXe / DMX-4
Batteries, Fans, Management Controllers, I/O Modules, Memory, Ports, Power Supplies
HPE 3PAR* Adapter cards, Batteries, CPU, Disks, Fans, Memory, Network port, Power Supply, SFP
HPE Alletra 5000/6000 Controllers, Disks, Ethernet ports, Fans, Fiber Channel ports, Power supplies, SAS ports
HPE Alletra 9000 Adapter cards, Batteries, CPU, Disks, Fans, Memory, Network port, Power Supply, SFP
HPE GreenLake for Block Adapter cards, Batteries, CPU, Disks, Fans, Memory, Network port, Power supply, SFP
HPE MSA Gen 6 (1060, 2060/2062) and Gen 7 (2070/2072) Swordfish Enclosure, Power Supply, Battery, Fan, Temperature, Drives, Ports
HPE Nimble storage Controllers, Disks, Ethernet ports, Fans, Fiber Channel ports, Power supplies, SAS ports
HPE Primera
Adapter cards, Batteries, CPU. Disks. Fans, Memory, Network port, Power Supply, SFP
Huawei Oceanstor Batteries, Disks, Fans, FC port, Ethernet port, Front-end FC port
IBM FlashSystem (REST API) Enclosure, Node Canister, Power Supply, Battery, Disk, SAS Port, Ethernet Port
IBM SVC / V9000 / V7000 / V5000 / V3700 Ports
IBM XIV
Ports
Infinidat InfiniBox
Disks, Ethernet ports, Fiber Channel ports, HBA (Adapter), Infiniband ports, Power supply, Switches, UPS (Batteries)
Kaminario K2 Adapter, Batteries, Disks, Ports, Power Supply
NetApp Cluster Mode** Batteries, Disks, Fans (value), FC ports, Power supplies, SAS ports, Temperature
NetApp E-Series/EF-Series*** SFP, Battery, Temperature, Fans, Power Supply, IO Module, Memory module (Data cache), Disk
NetApp 7-Mode Disks (value), Shelf, FC ports, iSCSI ports
* To enable HPE 3PAR arrays for hardware health monitoring, see Enable HPE 3PAR array for hardware health monitoring.
** To enable NetApp cluster Mode arrays for hardware health monitoring, see What NetApp Cluster Mode permissions are required by Storage Resource Monitor?
***Hardware health is not available for SANtricity SMI-S Provider.
SRM hardware health widgets
If you have an array for which hardware health monitoring is enabled, the Hardware Health Overview widget is available. In addition, a hardware health tab is available to display the Hardware Details, Current Hardware Health, and Hardware Health widgets.
The tab is not displayed for arrays that do not currently support hardware health monitoring.
Shows the number of storage arrays and nodes that have hardware heath monitoring enabled, by status. Click on the icon to list the devices with this status.
Hardware Details
Lists hardware details such as status, manufacturer, model and last polling time for the selected array.
Lists the sensors enabled for the selected array, showing status and current value if applicable.
Click Manage Sensors to open the Enable hardware health monitoring for SRM page.
Hardware Health Shows a performance chart for each sensor over a selected period.
