- Release Notes
- SRM 2025.1.1 release notes
- SRM 2025.1 release notes
- SRM 2024.4.1 release notes
- SRM 2024.4 release notes
- SRM 2024.2.1 release notes
- SRM 2024.2 release notes
- SRM 2024.1.1 release notes
- SRM 2024.1 release notes
- SRM 2023.4.2 release notes
- SRM 2023.4.1 release notes
- SRM 2023.4 release notes
- SRM 2023.3.1 release notes
- SRM 2023.3 release notes
- SRM 2023.2.2 release notes
- SRM 2023.2.1 release notes
- SRM 2023.2 release notes
- SRM 2023.1.1 release notes
- SRM 2023.1 release notes
- SRM 2022.4.1 release notes
- SRM 2022.4 release notes
- SRM Hotfixes
- SRM release history
- Install or Upgrade
- Get Started
- Administer
- SRM Administrator Guide
- Introduction to Storage Resource Monitor
- Add arrays to SRM
- Supported arrays (A - H)
- Monitor Dell EMC Compellent arrays in SRM
- Monitor Dell EMC EqualLogic PS series arrays in SRM
- Monitor Dell EMC PowerVault MD3xxx arrays in SRM
- Monitor Dell PowerStore T or Q arrays in SRM
- Monitor Dell PowerScale arrays in SRM
- Monitor Dot Hill AssuredSAN 4xxx/5xxx arrays in SRM
- Monitor EMC Data Domain arrays in SRM
- Monitor EMC Isilon/Dell PowerScale arrays in SRM
- Monitor EMC Symmetrix VMAX/VMAXe/DMX-4 arrays in SRM
- Monitor EMC Unity arrays in SRM
- Monitor EMC VNX / Clariion arrays in SRM
- Monitor EMC VMAX3 and VMAX All Flash Family (HYPERMAX OS) arrays in SRM
- Monitor EMC VNX NAS Gateway / Celerra arrays in SRM
- Monitor EMC XtremIO arrays in SRM
- Monitor HDS (External Provider) arrays in SRM
- Monitor HDS (Onboard Provider) arrays in SRM
- Monitor HPE 3PAR / StoreServ arrays in SRM
- Monitor HPE Alletra 5000/6000 arrays in SRM
- Monitor HPE Alletra 9000 arrays in SRM
- Monitor HPE GreenLake for Block arrays in SRM
- Monitor HPE P2xxx/MSA arrays in SRM
- Monitor HPE Primera arrays in SRM
- Monitor HPE StorageWorks XP (External Provider) arrays in SRM
- Monitor HPE StorageWorks XP (Onboard Provider) arrays in SRM
- Monitor Huawei OceanStor Dorado arrays in SRM
- Monitor Huawei OceanStor V3 / V5 (External) arrays in SRM
- Monitor Huawei OceanStor V3/V5 array with onboard provider arrays in SRM
- Supported arrays (I - Z)
- Monitor IBM DS3xxx/DS4xxx/DS5xxx arrays in SRM
- Monitor IBM DS 8xxx arrays in SRM
- Monitor IBM FlashSystem A9000 / A9000R arrays in SRM
- Monitor IBM N Series arrays in SRM
- Monitor IBM SVC / V9000 / V7000 / V5000 / V3700 arrays in SRM
- Monitor IBM XIV in SRM
- Monitor Infinidat InfiniBox arrays in SRM
- Monitor Kaminario K2 arrays in SRM
- Monitor LSI arrays in SRM
- Monitor NetApp E- and EF-Series arrays
- Monitor NetApp Filer (Direct Polling) arrays in SRM
- Monitor NetApp 7-Mode and Clustered Data ONTAP arrays in SRM using the NetApp OnCommand Unified Manager
- Monitor NetApp FAS/AFF arrays in SRM using the NetApp ONTAP REST API
- Monitor NetApp ONTAP arrays in SRM using the NetApp Active IQ Unified Manager (AIQUM) REST API
- Monitor HPE Nimble Storage arrays in SRM
- Monitor Pure Storage arrays in SRM
- Configure your storage arrays for SRM
- Manage arrays, providers, and credentials in SRM
- Add your storage array for monitoring with SRM
- Unmanage and remanage an array in SRM
- EMC XtremIO and Pure Storage capacity savings technologies
- Getting Started Monitoring File Storage for EMC VNX Arrays
- Administer SRM
- Log in to the SolarWinds Platform SolarWinds Platform Web Console
- Views and widgets in SRM
- Manage SRM settings
- Edit storage object properties in SRM
- Edit array polling frequencies
- Change the NetApp device polling method in SRM and migrate historical data
- Manage thresholds for SRM
- Monitor hardware health for SRM
- Storage Controller monitoring
- Use alerts with SRM
- Run reports in SRM
- SRM solutions
- Widgets
- SRM Resources
- SRM widgets (A - C)
- Aggregated NAS Volume Capacity
- All Active Alerts on Storage Objects or Active Alerts on this...
- All Storage Objects
- Array Details
- Array Polling Details
- Array Status widget in SRM
- Arrays on this Server widget in SRM
- Capacity Summary
- Custom Properties for File Shares
- Custom Properties for LUNs
- Custom Properties for Pools
- Custom Properties for Storage Arrays
- Custom Properties for Storage Providers
- Custom Properties for Volumes
- Custom Properties for VServers
- SRM widgets (D - M)
- SRM widgets (N - S)
- NAS CIFS/SMB Shares
- NAS NFS Exports
- NAS Volumes by Performance
- Performance Comparison
- Performance Summary
- Raw Disk Capacity Summary
- Read/Write IOPS Ratio / Cache Hit Ratio
- Server Details
- Server Volumes by Capacity
- Servers on this...
- Storage Objects by Capacity Risk
- Storage Objects by Performance Risk
- Storage Pool Capacity Summary
- Storage Pool Details
- SRM widgets (T - V)
- Thick LUNs
- Thick NAS Volumes (by Capacity)
- Thick Storage Pools (by Capacity)
- Thin LUNs
- Thin NAS Volumes (by Capacity)
- Thin Storage Pools (by Capacity)
- Throughput Performance
- Top XX LUNs by Total IOPS
- Top XX NAS Volumes by Total IOPS
- Usable Capacity Summary
- NAS Volume Details
- Vserver Details
- Vserver Management
- Vservers on this Cluster
EMC XtremIO arrays are monitored through onboard REST APIs.
For information on enabling this array, see the Enable an EMC XtremIO array knowledge base article.
After the array is enabled, you can begin monitoring as described in Add your storage array for monitoring with SRM.
