Thick LUNs
This widget lists all thick LUNs associated with the selected storage pool.
A thick LUN is a LUN that has all of its capacity reserved and allocated when created.
For each LUN, the LUN status and name, associated endpoint, total size, and file system used capacity (if known) is displayed. Used capacity is highlighted in yellow or red if the warning or critical threshold has been reached or exceeded.
LUNs can be sorted by any column.
You can search the list of LUNs by entering any part of the LUN name in the search box.
Click Edit to:
- Change the title and subtitle.
- Specify the number of LUNs displayed.
