Manage thresholds for SRM
SolarWinds Platform products provide two threshold levels: critical and warning. Many SRM widgets can display a critical or warning status when a monitored value on a device exceeds thresholds. You can override all storage objects of the same type (for example, all storage arrays in your monitored environment) or for individual objects for predefined static thresholds.
Thresholds can be used to define trigger conditions when creating alerts.
To change the value for a threshold, you can use a static threshold or a dynamic baseline threshold.
- A static threshold is a constant value. For example, the global warning threshold for LUN latency might be 50 ms, and the critical value might be 100 ms. You should be familiar with the performance of that object type or specific object to set a value for a static threshold is across your environment.
- A dynamic baseline threshold uses deviation from the mean value to determine critical and warning thresholds. Dynamic baseline thresholds can only be set for individual objects.
            Dynamic thresholds require data to be collected for a week for an accurate baseline to be determined. This is then used to calculate mean and standard deviations. The warning and critical threshold values are defined as two or three standard deviations above the mean.
For information on setting thresholds in SRM, see:
