Documentation forStorage Resource Monitor
IOPS Performance per Related LUN or NAS Volume
This widget provides a chart comparing input/output operations per second (IOPS) for the current LUN or NAS volume with the other LUNs or NAS volumes in the same storage pool.
You can select Read, Write, Other, or Total data.
You can select which LUNs or Volumes are shown, and also show the aggregate total for the pool.
You can display performance data for the last hour, the last 12 hours, or the last 24 hours using the Zoom buttons, or set the start and end points from the historical data selection to select a custom period, by setting the start and end points from the historical data selection shown below the charts.
Click Edit to:
  • Change the title and subtitle of the widget.
  • Change the maximum number of LUNs or volumes to be displayed.
  • Change the default zoom range, amount of historical data to load, and sample interval.
  • Add a chart title and subtitle.
