Documentation forStorage Resource Monitor
Capacity Summary
For LUNs, volumes, and file shares, this widget shows basic capacity information.
Total Size
Total capacity of the object.
File System Used
The sum of used capacity of server volumes created on this object and monitored in SRM. The server volumes created must be manually or automatically mapped to the object to be reported here.
Consumed
Total amount of space allocated for this object.
Projected Run-Out
Estimated time remaining before the object runs out of space. This projection is calculated using the last three months of statistics.
Remaining
Total Size less the amount of consumed capacity.
This chart may also include a tree structure showing the capacities of the immediate children of the current object.
Click Edit to:
  • Change the title and subtitle of the widget.
