Documentation forStorage Resource Monitor
Management
This widget provides links than enable the management of the selected array or cluster.
Edit Array/Cluster Click to open the Edit storage object properties in SRM page for this device, where you can edit the name, polling frequencies, array credentials, custom properties and alerting thresholds for this array or cluster.
Unmanage
Click to suspend or resume polling for this array or cluster. You can specify a start and end date for the period you want the device to be unmanaged.
If the device is currently unmanaged, this link will show Manage. Click to immediately start polling data again.
Statistics Poll Click to immediately gather performance data for this device.
Topology Poll Click to immediately gather LUN masking data for this device.
Controller Poll Click to immediately gather controller data for this device.
Rediscover Click to initiate an immediate rediscovery of this device, to ensure all attached entities have been discovered.
Map Server Volumes Click to open the Manual Server Volume Mapping page, enabling you to manually map volumes from servers where automatic mapping is not currently available.
Performance Analyzer Click Performance Analyzer to use the Performance Analysis dashboard (PerfStack™) to correlate historic data from SRM and many SolarWinds products in a single view.
Click Edit to change the title and subtitle.
