Thick Storage Pools (by Capacity)
When displayed on a summary dashboard, this widget provides a lists of all storage pools being monitored in the storage environment.
When displayed on a storage object detail page, this widget provides a lists of all storage pools being monitored for the object.
A thick storage pool is one that has all of its capacity reserved and allocated when created.
For each storage pool, the status and name, type, total size, and provisioned capacity. Provisioned capacity is highlighted in yellow or red if the warning or critical threshold has been reached or exceeded.
Storage pools can be sorted by any column.
You can search the list of pools by entering any part of the storage pool name in the search box.
Click Edit to:
- Change the title and subtitle.
- Specify the number of storage pools displayed.
