- Release Notes
- SRM 2025.1.1 release notes
- SRM 2025.1 release notes
- SRM 2024.4.1 release notes
- SRM 2024.4 release notes
- SRM 2024.2.1 release notes
- SRM 2024.2 release notes
- SRM 2024.1.1 release notes
- SRM 2024.1 release notes
- SRM 2023.4.2 release notes
- SRM 2023.4.1 release notes
- SRM 2023.4 release notes
- SRM 2023.3.1 release notes
- SRM 2023.3 release notes
- SRM 2023.2.2 release notes
- SRM 2023.2.1 release notes
- SRM 2023.2 release notes
- SRM 2023.1.1 release notes
- SRM 2023.1 release notes
- SRM 2022.4.1 release notes
- SRM 2022.4 release notes
- SRM Hotfixes
- SRM release history
- Install or Upgrade
- Get Started
- Administer
- SRM Administrator Guide
- Introduction to Storage Resource Monitor
- Add arrays to SRM
- Supported arrays (A - H)
- Monitor Dell EMC Compellent arrays in SRM
- Monitor Dell EMC EqualLogic PS series arrays in SRM
- Monitor Dell EMC PowerVault MD3xxx arrays in SRM
- Monitor Dell PowerStore T or Q arrays in SRM
- Monitor Dell PowerScale arrays in SRM
- Monitor Dot Hill AssuredSAN 4xxx/5xxx arrays in SRM
- Monitor EMC Data Domain arrays in SRM
- Monitor EMC Isilon/Dell PowerScale arrays in SRM
- Monitor EMC Symmetrix VMAX/VMAXe/DMX-4 arrays in SRM
- Monitor EMC Unity arrays in SRM
- Monitor EMC VNX / Clariion arrays in SRM
- Monitor EMC VMAX3 and VMAX All Flash Family (HYPERMAX OS) arrays in SRM
- Monitor EMC VNX NAS Gateway / Celerra arrays in SRM
- Monitor EMC XtremIO arrays in SRM
- Monitor HDS (External Provider) arrays in SRM
- Monitor HDS (Onboard Provider) arrays in SRM
- Monitor HPE 3PAR / StoreServ arrays in SRM
- Monitor HPE Alletra 5000/6000 arrays in SRM
- Monitor HPE Alletra 9000 arrays in SRM
- Monitor HPE GreenLake for Block arrays in SRM
- Monitor HPE P2xxx/MSA arrays in SRM
- Monitor HPE Primera arrays in SRM
- Monitor HPE StorageWorks XP (External Provider) arrays in SRM
- Monitor HPE StorageWorks XP (Onboard Provider) arrays in SRM
- Monitor Huawei OceanStor Dorado arrays in SRM
- Monitor Huawei OceanStor V3 / V5 (External) arrays in SRM
- Monitor Huawei OceanStor V3/V5 array with onboard provider arrays in SRM
- Supported arrays (I - Z)
- Monitor IBM DS3xxx/DS4xxx/DS5xxx arrays in SRM
- Monitor IBM DS 8xxx arrays in SRM
- Monitor IBM FlashSystem A9000 / A9000R arrays in SRM
- Monitor IBM N Series arrays in SRM
- Monitor IBM SVC / V9000 / V7000 / V5000 / V3700 arrays in SRM
- Monitor IBM XIV in SRM
- Monitor Infinidat InfiniBox arrays in SRM
- Monitor Kaminario K2 arrays in SRM
- Monitor LSI arrays in SRM
- Monitor NetApp E- and EF-Series arrays
- Monitor NetApp Filer (Direct Polling) arrays in SRM
- Monitor NetApp 7-Mode and Clustered Data ONTAP arrays in SRM using the NetApp OnCommand Unified Manager
- Monitor NetApp FAS/AFF arrays in SRM using the NetApp ONTAP REST API
- Monitor NetApp ONTAP arrays in SRM using the NetApp Active IQ Unified Manager (AIQUM) REST API
- Monitor HPE Nimble Storage arrays in SRM
- Monitor Pure Storage arrays in SRM
- Configure your storage arrays for SRM
- Manage arrays, providers, and credentials in SRM
- Add your storage array for monitoring with SRM
- Unmanage and remanage an array in SRM
- EMC XtremIO and Pure Storage capacity savings technologies
- Getting Started Monitoring File Storage for EMC VNX Arrays
- Administer SRM
- Log in to the SolarWinds Platform SolarWinds Platform Web Console
- Views and widgets in SRM
- Manage SRM settings
- Edit storage object properties in SRM
- Edit array polling frequencies
- Change the NetApp device polling method in SRM and migrate historical data
- Manage thresholds for SRM
- Monitor hardware health for SRM
- Storage Controller monitoring
- Use alerts with SRM
- Run reports in SRM
- SRM solutions
- Widgets
- SRM Resources
- SRM widgets (A - C)
- Aggregated NAS Volume Capacity
- All Active Alerts on Storage Objects or Active Alerts on this...
- All Storage Objects
- Array Details
- Array Polling Details
- Array Status widget in SRM
- Arrays on this Server widget in SRM
- Capacity Summary
- Custom Properties for File Shares
- Custom Properties for LUNs
- Custom Properties for Pools
- Custom Properties for Storage Arrays
- Custom Properties for Storage Providers
- Custom Properties for Volumes
- Custom Properties for VServers
- SRM widgets (D - M)
- SRM widgets (N - S)
- NAS CIFS/SMB Shares
- NAS NFS Exports
- NAS Volumes by Performance
- Performance Comparison
- Performance Summary
- Raw Disk Capacity Summary
- Read/Write IOPS Ratio / Cache Hit Ratio
- Server Details
- Server Volumes by Capacity
- Servers on this...
- Storage Objects by Capacity Risk
- Storage Objects by Performance Risk
- Storage Pool Capacity Summary
- Storage Pool Details
- SRM widgets (T - V)
- Thick LUNs
- Thick NAS Volumes (by Capacity)
- Thick Storage Pools (by Capacity)
- Thin LUNs
- Thin NAS Volumes (by Capacity)
- Thin Storage Pools (by Capacity)
- Throughput Performance
- Top XX LUNs by Total IOPS
- Top XX NAS Volumes by Total IOPS
- Usable Capacity Summary
- NAS Volume Details
- Vserver Details
- Vserver Management
- Vservers on this Cluster
This section provides information for configuring your provider to facilitate communication between the Dot Hill array and SRM.
Dot Hill AssuredSAN 4xxx/5xxx arrays are monitored through a combination of an onboard SMI-S Provider and XML APIs on the array.
For information on enabling the array, see the Dot Hill AssuredSAN 4xxx/5xxx array knowledge base article.
After the array is enabled, you can begin monitoring as described in Add your storage array for monitoring with SRM.
