Latency Performance per Related LUN or NAS Volume
This widget charts the latency for the current LUN or NAS volume compared with the other LUNS or NAS volumes in the same storage pool. The chart shows the warning and critical threshold for this object.
You can select Read, Write, Other, or Total data.
You can select which LUNs or volumes are displayed.
You can display performance data for the last hour, the last 12 hours or the last 24 hours using the Zoom buttons, or select a custom period by setting the start and end points from the historical data selection shown below the charts.
Click Edit to:
- Change the title and subtitle.
- Change the maximum number of LUNs or NAS volumes displayed.
- Change the default zoom range.
Change the amount of historical data to load, and specify the sample interval.
- Add a chart title and subtitle.
