Top XX NAS Volumes by Total IOPS
Displays a graph showing the performance over the selected time period for the top performing NAS volumes attached to the current storage object with the highest total IOPS. By default the top ten performing NAS volumes are displayed.
You can hide any of the volumes for clarity.
You can display performance data for the last hour, the last 12 hours, or the last 24 hours using the Zoom buttons, or set the start and end points from the historical data selection to select a custom period, by setting the start and end points from the historical data selection shown below the charts.
Click Edit to:
- Change the title and subtitle of the widget.
- Change the maximum number of volumes to be displayed.
- Change the default zoom range, amount of historical data to load, and sample interval.
- Add a chart title and subtitle.
