Documentation forVoIP & Network Quality Manager
Rename operations in SolarWinds VNQM
Any operation that VoIP and Network Quality Manager monitors is given a default name using the following pattern: SourceNodeName -> TargetNodeName, where SourceNodeName is the name of the source node and TargetNodeName is the name of the target node. To change the name of an operation, complete the following procedure.
  1. Click Settings > All Settings.
  2. Under Product Specific Settings, click VoIP & Network Quality (VNQM) Settings.
  3. Under Manage Network Service Assurance Operations, click Edit or delete operations.
  4. Select the operation you want to modify, and click Edit.
  5. Enter the new name for the operation, and click Save.
  • Leaving the Operation Name field blank results in the operation being named using the default naming pattern.
  • If you change the name of a node in NPM, the change will be reflected in the operation name unless the default naming pattern is not being used.
