Add UDP Jitter Network Service Assurance operations to devices
User Datagram Protocol (UDP) Jitter Network Service Assurance operations measure WAN quality by testing connection times between two devices using a specific port number. These operations ensure that your WAN is operational and performing as expected.
You cannot add operations that have been previously created with VoIP and Network Quality Manager. If you have already created an operation with the same operation number, you must manually remove the operation from the device.
- Log in to your VoIP and Network Quality Manager server as an administrator.
- Click Settings > All Settings.
- Under Product Specific Settings, click VoIP & Network Quality (VNQM) Settings.
- Under Manage Network Service Assurance Operations, click Add new operations.
- Select Create new operations, and click Next.
- Select UDP Jitter, and click Next.
- Select the type of path your network is configured to use. For more information, see Designate paths in SolarWinds VNQM.
- Select the source nodes you want to add to your new UDP Jitter operations, and click Next.
If you do not see your Network Service Assurance routers in the list, you must add the devices before you can continue. For more information, see Adding Devices for Monitoring in the Web Console.
- Select the target nodes you want to add to your new UDP Jitter operation.
- To create the path in only one direction, select No, create the path in just one direction.
- To specify an external node as a target, complete the following procedure.
- Click Yes, use external node as a target.
- Enter the IP address or host name of the external node you want to add.
If you are using a host name, the source node of the operation must be able to successfully resolve the host name.
- Enter the frequency for the operation to be performed.
- Enter the port number to be used in the test in the Port Number field.
- Define your warning, critical, and maximum threshold values.
- To assign a type of service (ToS) or Virtual Routing and Forwarding (VRF) name for this path, expand Advanced, and type the type of service number and VRF name in the appropriate fields.
- The ToS octet is a decimal value (0-255) that sets the precedence for VoIP traffic monitored with Network Service Assurance operations. The default ToS value used by VoIP and Network Quality Manager is
184, corresponding to Expedited Forwarding (EF) per hop behavior (PHB) and a Differentiated Service Code Point (DSCP) value of46. For more information about the ToS octet, see Setting Traffic Precedence. - VRFs only exist on provider edge routers (PE). A VRF is a routing and forwarding table instance, and you can have more than one VRF per PE. The VRF includes routes that are available to a certain set of sites. A VRF is named based on the VPNs it services and on the role of the CE in the topology.
- Click Next.
- To rename operations or edit any other operation properties, select the operations you want to modify, and click Edit.
- Review the operations you want to create, and click Create Operations.
Depending on the number of operations that are being created, this process can take several minutes.
- Click Go to VNQM Home to finish the procedure and return to the VoIP and Network Quality Manager home page.
