Documentation forVoIP & Network Quality Manager
Quality of Service and Network Service Assurance in SolarWinds VNQM
Network Service Assurance is a diagnostic method that generates and analyzes traffic between Cisco IOS and Juniper RPM devices on your network. By using VoIP and Network Quality Manager to implement Network Service Assurance operations between your network devices, you can acquire real-time and historical statistics that give you accurate Quality of Service (QoS) measurements over designated network paths between a source device and a target device.
For a better understanding of individual quality of service and Network Service Assurance, it is necessary to understand the following concepts:
Source
A device that creates and inserts Network Service Assurance packets into the network. The source is where all Network Service Assurance operation tests are initiated.
Target
The ultimate destination of the packets created and sent by the source.
Operation
The type of test being performed on the network.
Network Service Assurance Operations in VNQM
The following operations are supported by VoIP and Network Quality Manager.
  • DHCP: measures the response time taken to discover a DHCP server, and then obtain a leased IP address from it.
  • DNS: measures the difference in time from when a DNS request is sent and when the reply is received.
  • FTP: measures the response time between a Cisco device and an FTP server to retrieve a file.
  • HTTP: measures distributed web services response times.
  • ICMP Echo: measures round trip time between nodes on the network.
  • ICMP Path Echo: measures round trip time hop-by-hop between nodes on the network.
  • ICMP Path Jitter: measures WAN quality by testing connection times hop-by-hop between two devices.
  • TCP Connect: measures WAN quality by testing connection times between two devices using a specific port.
  • UDP Echo: measures round trip time between nodes on the network.
  • UDP Jitter: measures WAN quality by testing connection times between two devices using a specific port number.
  • VoIP UDP Jitter: measures call path metrics on the VoIP network.
