Avaya CDR parameters
To take advantage of CDR polling in VoIP and Network Quality Manager, at least the following Avaya™ CDR parameters must be configured:
dialed-numcalling-num, orclg-num/in-tacstart-date(4d)orstart-datestart-timeend-date(4d),end-date, ordateend-time, ortimecond-code
If your Avaya setup makes it necessary, you can substitute certain parameters with different ones, and use them in the following way:
- Instead of the
start-timeparameter, you can use thetimeandsec-durparameters. - Instead of the
start-timeparameter, you can use theend-timeandsec-durparameters. - Instead of the
end-timeparameter, you can use thestart-timeandsec-durparameters. - Instead of the
The order in which you configure CDR parameters is not relevant.
- To be able to use the start-date, start-date(4d), end-date(4d), start-time, and end-time CDR custom fields, you must enable the SA8201-Start Time and the 4-Digit Year CDR Custom fields special application.
- You must also enable the SA8202-Intra-switch CDR by COS special application.
