Add FTP Network Service Assurance operations to devices
File Transfer Protocol (FTP) Network Service Assurance operations measure the response time between a device and an FTP server to retrieve a file. These operations run on Network Service Assurance-capable devices, and they ensure that your FTP servers are operational and performing as expected.
You cannot add operations that have been previously created with VoIP and Network Quality Manager. If you have already created an operation with the same operation number, you must manually remove the operation from the device.
- Log in to your VoIP and Network Quality Manager server as an administrator.
- Click Settings > All Settings.
- Under Product Specific Settings, click VoIP & Network Quality (VNQM) Settings.
- Under Manage Network Service Assurance Operations, click Add new operations.
- Select Create new operations, and click Next.
- Select FTP, and click Next.
- Select the nodes you want to add to your new FTP operations, and click Next.
If you do not see your Network Service Assurance routers in the list, you must add the devices before you can continue. For more information, see Adding Devices for Monitoring in the Web Console.
- Enter the URL of the FTP server, and click Next.
- Enter the frequency for the operation to be performed.
- Define your warning, critical, and maximum threshold values.
- To assign a type of service (ToS) or Virtual Routing and Forwarding (VRF) name for this path, expand Advanced, and enter the type of service number and VRF name.
- The ToS octet is a decimal value (0-255) that sets the precedence for VoIP traffic monitored with Network Service Assurance operations. The default ToS value used by VoIP and Network Quality Manager is
184, corresponding to Expedited Forwarding (EF) per hop behavior (PHB) and a Differentiated Service Code Point (DSCP) value of46. For more information about the ToS octet, see Setting Traffic Precedence. - VRFs only exist on provider edge routers (PE). A VRF is a routing and forwarding table instance, and you can have more than one VRF per PE. The VRF includes routes that are available to a certain set of sites. A VRF is named based on the VPNs it services and on the role of the CE in the topology.
- Click Next.
- To rename operations or edit any other operation properties, select the operations you want to modify, and click Edit.
- Review the operations you want to create, and click Create Operations.
Depending on the number of operations that are being created, this process can take several minutes.
- Click Go to VNQM Home to finish the procedure and return to the VoIP and Network Quality Manager home page.
