Supported versions of Cisco Unified Communications Manager (CallManager)
VoIP and Network Quality Manager uses the CISCO-CCM-MIB and supports Cisco® Unified Communications Manager (CallManager) versions 6 through 15.
If you have multiple polling engines, you must install the same version of VNQM on all polling engines before you will be able to add a CallManager server.
The following table lists the OIDs used for CallManager.
| Name | OID |
| ccmRegisteredPhones | 1.3.6.1.4.1.9.9.156.1.5.5.0 |
| ccmUnregisteredPhones | 1.3.6.1.4.1.9.9.156.1.5.6.0 |
| ccmRejectedPhones | 1.3.6.1.4.1.9.9.156.1.5.7.0 |
| ccmRegisteredGateways | 1.3.6.1.4.1.9.9.156.1.5.8.0 |
| ccmUnregisteredGateways | 1.3.6.1.4.1.9.9.156.1.5.9.0 |
| ccmUnregisteredGateways | 1.3.6.1.4.1.9.9.156.1.5.10.0 |
