SolarWinds VNQM map variables
The following list of variables can be used when creating labels for your map objects.
Variable |
Description |
DateChangedUtc |
The last time the operation information was updated |
Deleted |
Indicates if the operation has been deleted from VoIP and Network Quality Manager |
Description |
A user defined explanation of the operation |
DetailsUrl |
Link to the detail page |
DisplaySource |
The source node |
DisplayTarget |
The target node |
Frequency |
How often the operation is performed |
IpSlaOperationNumber |
The internal number of the operation |
IsAutoConfigured |
This value is True if it was created by VoIP and Network Quality Manager, False if it was created by the user |
LifetimeUtc |
The timeframe of when the operation is executed |
NodeID |
The ID of the node |
OperationInstanceID |
The internal ID of the operation |
OperationName |
The name of the operation as it appears in the database |
OperationResultID |
The ID of the results of the operation |
OperationResultRecordTime |
The timestamp of when the operation was performed |
OperationStateID |
The ID of the operation state |
OperationStatusID |
The ID of the operation status |
OperationType |
The value of the operation type |
OperationTypeID |
The ID of the operation type |
SourceNodeID |
The node ID of the source node |
StatusMessage |
A message that describes the status value |
TargetNodeID |
The node ID the operation is targeting |
For more information about creating maps, see the Intelligent Maps for SolarWinds Platform products.
