Documentation forVoIP & Network Quality Manager
Add existing operations to SolarWinds VNQM
With VoIP and Network Quality Manager you can monitor operations that are already configured on a device. To do so, add these operations to VNQM.
Path operations require CLI credentials to be discovered by VNQM. Cisco Nexus devices are required to have CLI credentials in VNQM to discover existing operations.
  1. Log in to your VoIP and Network Quality Manager server as an administrator.
  2. Click Settings > All Settings.
  3. Under Product Specific Settings, click VoIP & Network Quality (VNQM) Settings.
  4. Under Manage Network Service Assurance Operations, click Add new operations.
  5. Select Monitor existing operations, and click Next.
  6. If you want to automatically discover operations on your nodes, complete the following procedure.
    1. Select Automatically discover existing operations, and click Next.
    2. Select the node where the operation you want to monitor resides, and click Next.
      If you have not entered valid CLI credentials for the selected node, you may be prompted to enter credentials. You do not have to provide credentials to the node.
    3. Select the operation you want to monitor, and click Monitor Operations.
  7. If you want to manually enter the operation numbers, expand Advanced, and complete the following procedure.
    1. Select Manually enter operation numbers, and click Next.
    1. Enter the operation number, and click Next.
    2. Select the operation you want to monitor, and click Monitor Operations.
  8. Click Go to VNQM Home to finish the procedure and return to the VoIP and Network Quality Manager home page.
