Documentation forVoIP & Network Quality Manager
Calculated series in SolarWinds VNQM
In your graphs, you can display markers calculated from historical data. By using these markers, you can compare the current situation with the calculated series.
To display markers in the graph, select the appropriate options:
  • Show a trend line displays the trend line, allowing you to see potential future results as they are extrapolated from collected historical data.
  • Show the sum of all data series displays a line showing the total of all objects graphed.
  • Show the 95th percentile line displays the 95th percentile marker. For more information, see 95th Percentile Calculations.
Only the options applicable for the particular resource are available.
