Persistent Work Areas
Navigation Notice: When the APM Integrated Experience is enabled, Loggly shares a common navigation and enhanced feature set with other integrated experience products. How you navigate Loggly and access its features may vary from these instructions.
Loggly loves multitaskers, so it allows you to create multiple work pages. As a result, you can investigate several issues in parallel without losing your state. Each tab will keep its own search context state, including Source Group, query terms, time range, and filters. Once you create a work page, it’s automatically saved there until you remove it. If you restart your browser, reboot your computer, or change devices, all your work pages are saved just as you left them.
How To Do It
1. On the search page, click the +New icon to create a new work page.
2. Click the work page title to rename it as you see fit. For example, you may name it based on the type of task for which it is used.
3. Once you create a tab, it’s there until you remove it. If you change desktops, browsers, etc, the search context will save the current state.
