Documentation forLoggly
Send Amazon Cloudfront Logs to Loggly
Loggly provides the infrastructure to aggregate and normalize log events so they are available to explore interactively, build visualizations, or create threshold-based alerting. In general, any method to send logs from a system or application to an external source can be adapted to send logs to Loggly. The following instructions provide one scenario for sending logs to Loggly.
You can push Amazon Cloudfront logs to Loggly using an AWS Lambda Script. The script converts Cloudfront gzipped logs written to S3 into JSON format and then sends them to Loggly.
Alternatively, you can use the S3 ingestion service that directly ingests logs into Loggly without requiring a Lambda function.
Set up AWS
  1. Get the Lambda Code
    Clone the git repo
                        git clone https://github.com/fgheorghe/cloudfront2loggly.git
    cd cloudfront2loggly
    Edit cloudfront2loggly.js with the proper Loggly customer token. In the code below, replace TOKEN with your customer token from the source setup page.
                        logglyConfig = {
      tag: "aws-cloudfront",
      token: "TOKEN"
    Install required npm packages.
                        npm install
    Zip up your code.
                        zip -r cloudfront2loggly.zip cloudfront2loggly.js node_modules
    The resulting zip file (cloudfront2loggly.zip) is what you upload to AWS in Step 2 below.
  2. Configure the Lambda Function
    Use the AWS Console to create a cloudfront2loggly Lambda function. See Create a Lambda function with the console in the AWS documentation for more information.
    When prompted, provide the information below:
    Upload lambda function: (select the zip file you created in Step 1)
    Handler*: cloudfront2loggly.handler
    Role*: S3 execution role (if a new window opens to create the role, click Allow)
    Memory: Set to 128MB
    Timer: Set to 10 seconds
    Configure the Event Source to call cloudfront2loggly when logs are added to the S3 bucket. When prompted, provide the information below.
    Event source type: S3
    Bucket: Choose the bucket that contains your Cloudfront logs
    Event type: All object create events
    If additional information is needed, see Using AWS Lambda with Amazon S3.
  3. Configure Cloudfront Logging
    Go to the Cloudfront app.
    In your distribution settings, enable logging and select the S3 bucket for logs.
  4. Verify Events
    Search Loggly events for tag:aws-cloudfront in the last 30 minutes. It may take a few minutes to index the events.
    If indexing doesn’t work, see Troubleshooting.
Advanced AWS Cloudfront Options
AWS Cloudfront Logging – How to setup AWS Cloudfront logging to a S3 bucket
Learn how Loggly can help with all of your AWS Log Management
Troubleshooting
If you don’t see any data show up in the verification step, check for these common problems.
  • Wait a few minutes in case indexing needs to catch up.
  • Make sure you’ve included your own customer token.
  • Make sure you have configured the same roles as mentioned above.
  • Search or post your own Amazon Cloudfront logging questions in the community forum.
