Docker Logging Strategies
Loggly provides the infrastructure to aggregate and normalize log events so they are available to explore interactively, build visualizations, or create threshold-based alerting. In general, any method to send logs from a system or application to an external source can be adapted to send logs to Loggly. The following instructions provide one scenario for sending logs to Loggly.
There are several ways of getting your Docker logs to Loggly. We made this guide to help you choose the best one for your needs. For more comparison details, read our blog Top Docker Logging Methods to Fit Your Container Deployment Strategy
Option 1: Logging via the Docker Logging Driver (Recommended)
This method uses the Docker service to read stdout and stderr output generated by containers. The default configuration writes logs to a file on the host machine, but changing the logging driver lets you forward messages to syslog, journald, gelf, or other endpoints. Refer to Docker Logging Driver for more information.
Benefits |
Drawbacks |
When Should I Use It? |
Recommended for most common uses |
Option 2: Logging via a Dedicated Logging Container
A dedicated logging container serves the sole purpose of consuming log events. Running it as a container lets you make your logging solution a part of your architecture. Refer to Docker Logging Through Syslog for more information.
| Benefits | Drawbacks | When Should I Use It? |
Use when you’d like to aggregate logs locally before sending to Loggly |
Option 3: Logging via the Sidecar Approach
Like the dedicated logging approach, the sidecar approach uses logging containers. The difference is that it pairs each application container with its own dedicated logging container. It can be implemented using mounted volumes to share logs between containers, as discussed in the linked blog. It can also work with a logspout container. For more information see How to implement logging in Docker with a sidecar approach from the Loggly blog.
Use in a large, distributed architecture where you still need fine-tuned control over your logging solution |
Option 4: Logging via the Application
This method requires each container to have its own internal methods for logging. This typically involves using a logging framework such as Logback, winston, or Log4Net to send log events to Loggly. For more information, see Logging Setup.
