Connect to a computer using Dameware Remote Support
This topic applies to Remote Support.
Before you connect to a computer internal to your network, ensure that you know the location of the computer within your network.
- Launch the Dameware Remote Support application.
- Enter login credentials and click Connect to Server.
- Browse the subnets under Active Directory until you locate the computer you want to support.
- Click the plus sign (+) next to the computer you want to support.
You are now ready to Modify end user machines using Dameware Remote Support.
