Dameware Mini Remote Control connection and authentication methods
This topic applies to both Remote Support and Mini Remote Control.
The Dameware Mini Remote Control application connects to the client agent service using a direct TCP connection from the application to the client agents. Although this method may not be as convenient as establishing a VPN or SSL connection to a LAN, for many users it provides a way of supporting customers or administrating remote computers not on a LAN.
Dameware Mini Remote Control supports the following connection methods:
| Connection Method | Description | Authentication Methods |
Use MRC Viewer |
Connects to the MRC agent installed on the remote Windows machine. If an agent is not installed on the remote machine, it is installed during the connection. |
Proprietary Challenge/Response: This authentication method works by having a custom proprietary User Name and Password defined in the settings of the Dameware Mini Remote Control client agent service on the remote system. The User Name and Password are stored in encrypted format in the Registry of the remote system. Windows NT Challenge/Response: This authentication method uses the integrated security of the Windows operating system to connect to a remote system. Encrypted Windows Logon: The Encrypted Windows Logon is similar to the Windows NT Challenge/Response authentication method except that it sends the User Name and Password to the remote system in an encrypted format. This authentication method is designed primarily for situations where NT Challenge/Response authentication is not possible or fails. Examples of these situations include when Domain Controllers have been configured to disallow anonymous connections, NT Challenge / Response has been disabled, or when using any of the Home versions of Windows Operating Systems. Smart Card Logon: The Smart Card Logon provides two-factor authentication that allows the Dameware Mini Remote Control user to authenticate to a remote system using a Smart Card and PIN at the local system without requiring a Smart Card reader at the remote system. This option works in conjunction with the Smart Card network implementation. |
Use Remote Desktop (RDP) |
Connects to the remote system using the Microsoft Remote Desktop Program. When you select this option, Dameware Mini Remote Control opens the RDP viewer within the Mini Remote Control application to connect to the remote system. |
N/A |
Use VNC Viewer (Linux or Mac) |
Connects to a remote VNC server using the Remote Frame Buffer (RFB) protocol. Use this option to connect to Linux or Mac hosts. For additional information about the operating systems Dameware Mini Remote Control supports for VNC connections, see Configure a Mac or Linux computer as a Dameware Remote Host. |
N/A |
