Integrate Dameware with SolarWinds Web Help Desk
The integration between Dameware Mini Remote Control and SolarWinds Web Help Desk (WHD) enables you to launch a Mini Remote Control session from within a WHD asset.
Complete the following tasks to integrate Dameware and WHD.
| Task | Description |
1. Install the Dameware Mini Remote Control application. |
For each technician, the Mini Remote Control application must be installed on the computer that is used to access WHD and to open a Mini Remote Control connection. When you open a DamewareMini Remote Control connection from WHD, the protocol handler opens the local copy of Mini Remote Control. |
2. Install the Dameware Mini Remote Control client service agent on each remote computer or asset. |
You cannot use a Dameware Mini Remote Control connection in Web Help Desk Integration mode to add or remove agents from the remote computer or asset. All assets must already have the Dameware Mini Remote Control agent installed on them before Dameware Mini Remote Control can connect to them. Dameware Mini Remote Control cannot install an agent when it is running in integration mode. You do not need to pre-install the Dameware Mini Remote Control agent to create Internet Sessions. Users download the Internet Session agent or Dameware Mini Remote Control agent from the Dameware Internet Proxy server. |
| 3. Assign an IP address to each asset. |
Each asset must have a valid IP address associated with it in WHD. |
| 4. Configure the Dameware and WHD integration. |
You must have administrator privileges in WHD to integrate the two products.
WHD creates a registry entry in your Web Help Desk installation that is used to open DamewareMini Remote Control. The configuration change creates a custom protocol handler (dwrcc) that is associated with the Dameware Mini Remote Control application on the local computer. Depending on your security settings, you may be prompted to allow the Dameware protocol handler to resolve and open Dameware Mini Remote Control. |
