Modify the Dameware Internet Session base URL
You can edit the Internet Session base URL that you send to remote users. This is an optional feature that enables you to personalize the Internet Session URL. You cannot change any other segment of the Internet Session URL.
In the following example, jsystem-lt is the Internet Session base URL.
- Log in to the Administration Console and click Internet Proxy > Settings.
- Select The base URL for Internet sessions.
- Click Edit in the Action bar.
- Enter the Internet Session base URL.
- Click OK.
- You can may modify the Internet Session Base URL by adding
/TEXTafter the local host name. For example,https://localhost/TEXT. - You cannot modify the local host name and port in the Administration Console. You must modify the local host name and port in the Configuration Wizard.
