Documentation forLoggly
Sending Syslog Endpoints to Loggly
Loggly provides the infrastructure to aggregate and normalize log events so they are available to explore interactively, build visualizations, or create threshold-based alerting. In general, any method to send logs from a system or application to an external source can be adapted to send logs to Loggly. The following instructions provide one scenario for sending logs to Loggly.
There are many ways to send syslog to Loggly. We have specific guides available for Linux systems, Windows systems, and Network Devices and Routers. This page describes more generically our syslog endpoints and accepted log formats.
Syslog Endpoints
We have two syslog endpoints available that accept both UDP and TCP syslog. Please see the advanced options section for instructions on how configure your specific systems.
For standard syslog please use:
logs-01.loggly.com:514
For secure syslog encrypted with TLS please use:
logs-01.loggly.com:6514
Syslog Header
We only accept syslog events with a RFC5424 compliant header. Within the header there must be a structured data set that includes your Customer Token and the Loggly private enterprise number (PEN) which is 41058. Here’s an example of a compliant syslog header:
<34>1 2003-10-11T22:14:15.003Z server1.com sudo - - [8bf8cc10-4140-4c3e-a2b4-e6f5324f1aea@41058]
If you use syslog, we can guarantee that your syslog headers and structured data will be extracted, independently of the actual message contents, provided you use our standard syslog configuration. These configs are based on the Syslog Protocol RFC5424, and we will extract the following fields (using RFC names):
PRIVAL, Facility, Severity, VERSION, TIMESTAMP, HOSTNAME, APP-NAME, PROCID, MSGID
Our standard config also allows you to define tags in the STRUCTURED-DATA part of the message. As an example, if your structured data looks like this:
[01234567-89ab-cdef-0123-456789abcdef@41058 tag="foo" tag=bah]
we will extract "foo" and "bah" as tags, which you can then use to refine searches using tag:foo for example, and which you can also use in the Trending tab.
Notice that we support unquoted values, even though the RFC says these values must be quoted.
Streaming Syslog Without Files
Many people think of logs as files, but you can also stream logs using syslog over the network without needing agents or writing logs to a file. There are many reasons to do this including for performance reasons if writes are too slow for your app, if you don’t have access to the file system, to create a centralized local log server, to log from network devices like routers or switches, or just for applications that stream syslog. Many applications are able to log directly to syslog including logger, Nginx, Apache error logs, and more. You can also write custom applications to log directly to syslog using libraries like syslog4j.
You can configure rsyslog and syslog-ng to accept syslog over localhost, or over your network from one or more servers or network devices. The syslog daemon will include headers with the LogglyFormat if necessary. If you send over TCP it will retry, and you can additionally configure a local in-memory queue. Added to the default configuration supplied by configure-syslog or the rsyslog manual configuration, this will configure rsyslog to accept events from the network interface and forward them to Loggly.
# Receive syslog over UDP
module(load="imudp") # needs to be done just once
input(type="imudp" port="514")
# Receive syslog over TCP
module(load="imtcp" MaxSessions="500")
input(type="imtcp" port="601")
Advanced Syslog Endpoint Options
Troubleshooting Your Syslog Endpoints
If you don’t see any data show up, then check for these common problems.
Check Your Syslog Daemon:
Still Not Working?
  • Search or post your own syslog endpoint questions in the community forum.
