Documentation forIP Address Manager
Top 10 Subnets by % IP Addresses Used
This widget shows the ten subnets being monitored with the highest percent IP space used. For each subnet, this widget shows the subnet name, the percentage of IP address space used, the IPs available and the IPs used.
Note that the calculation of space used takes into account IPs that are reserved or transient.
Click Edit to:
  • Change the widget title.
  • Change the maximum number of subnets displayed at a time.
  • Filter objects using simple SQL queries. For example:
      Subnet.CIDR = 24 to list only those subnets where CIDR is 24.
      Subnet.Address Like '10.10.*' to list only those subnets with an address beginning 10.10.
    The list of properties that can be used for filtering these subnets is displayed by clicking Show List of Subnet Properties.
