Troubleshooting DHCP and DNS connections in IPAM
| Problem | Description | Resolution |
Bad username or password |
This error may occur when the valid user account on the SolarWinds host has no meaning to the DHCP Server or when the provided password is not correct on the DHCP Server. |
The RPC Server is Unavailable |
This error may occur when the DHCP Server is unable to receive or respond to RPC Requests. |
| Insufficient permissions | Insufficient permissions |
BIND Credential fails using ssh or telnet option |
When adding a DNS Bind, in the BIND Credential option there is a space in the Credential name. For example: Credential Name: Bind 1 Username: root Password: 1234 |
Remove the space in the 'Credential Name' (should be Bind1) |
BIND DNS on AIX Symptom: Bind is not running error when testing the connection to implement BIND DNS Mgmt and add an AIX 6.1 Bind9 based DNS Server |
When the named-V and ps -A -o comm,pid,args | grep ^named commands are issued and parsing returns a value that does not match the criteria, the application is not enabled: named9 vs named |
Perform a manual configuration of the config file by renaming the file from named9 to named. |
IPAM BIND Requirements
- User account needs to be configured to allow remote telnet or SSH access to BIND machine.
- Read and write file access is required for all BIND configuration files.
- /etc/named.conf, and all included files
- all zone data files
- Read and write access to system temp directory /tmp
- IPAM utilizes both standard Linux commands (POSIX) and BIND specific commands that are required for IPAM BIND management functionality:
named
ps
grep
sha1sum
cat
if [ -r "filepath" ] ; then echo 'true'; else echo 'false'; fi
if [ -w "filepath" ] ; then echo 'true'; else echo 'false'; fi
if [ $? -eq 0 ] ; then echo 'true'; else echo 'false'; fi
cp
mkdir
rm
named-checkconf
