System variables
- Server information
- Server statistics
- Domain statistics
- User statistics
- Last transfer statistics
- Date/Time
- Server settings
- Session information
- File information
- Current activity
- FileShare
You can customize certain configurable messages in Serv-U to include a wide range of variables as outlined in the following list. These variables are replaced at run time with the appropriate value allowing up-to-date statistics and feedback to be provided to logged in users. Some of the places where you can use these variables include event messages, customized FTP command responses, or a welcome message.
Furthermore, you can also use the %USER%, %HOME%, %USER_FULL_NAME%, and %DOMAIN_HOME% variables. For more information about these variables, see Group properties: Directory access.
When you use macros, in general, it is best to use $ macros for events and in system messages (such as login messages or customized FTP responses) and % macros for configuration values. Many of the $ macros do not have explicit values until a session has been successfully established or a specific action has taken place, whereas the % macros have explicit values at all times.
All variables are case sensitive. Statistical information, unless otherwise specified, is calculated since the Serv-U File Server was last started.
Server information
| Variable | Description |
| $ServerName | Displays the full name of the server (that is, Serv-U). |
| $ServerVersionShort | Displays the first two digits of the current version of the Serv-U File Server (for example, 15.1). |
| $ServerVersionLong | Displays the full version number of the Serv-U File Server (for example, 15.1.0.480). |
| $OS | Displays the name of the operating system (for example, Windows Server 2008 R2). |
| $OSVer | Displays the full version number of the operating system (for example, 6.1.7601). |
| $OSAndPlatform | Displays the name of the operating system (for example, Windows Server 2008 R2) and platform (for example, 32-bit or 64-bit). |
| $OSCaseSensitive | States if the operating system is case sensitive. |
| $ComputerName | Displays the name of the computer retrieved from the operating system, normally the same as the UNC name on a Windows network (for example, WEB-SERVER-01). |
| $EventName | Contains the configured name of the event. |
| $EventType | Contains the type of the event that was triggered. |
| $EventDescription | Contains the configured description of the event. |
| $LogFilePath | Retrieves the path to the log file (Log File Deleted and Log File Rotated Events only). |
| $OldLogFilePath | Retrieves the old path to the log file (Log File Rotated Events only). |
| $GatewayIPAddress | Retrieves the Gateway IP address (Gateway Listener Success, Gateway Listener Failure, Permanent Gateway Listener Success, Permanent Gateway Listener Failure Events only). |
| $GatewayPort | Retrieves the Gateway port (Gateway Listener Success, Gateway Listener Failure, Permanent Gateway Listener Success, Permanent Gateway Listener Failure Events only). |
| $ListenerIPAddress | Retrieves the listener IP address (Listener Success, Listener Failure, Permanent Listener Success, Permanent Listener Failure Events only). |
| $ListenerPort | Retrieves the listener port (Listener Success, Listener Failure, Permanent Listener Success, Permanent Listener Failure Events only). |
| $ListenerType | Retrieves the listener type (Listener Success, Listener Failure, Permanent Listener Success, Permanent Listener Failure Events only). |
| $ListenResult | Retrieves the listener result (Listener Success, Listener Failure, Permanent Listener Success, Permanent Listener Failure Events only). |
Server statistics
| $ServerDays | Displays the total number of days the server has been online continuously. |
| $ServerHours | Displays the number of hours from 0 to 24 the server has been online, carries over to $ServerDays. |
| $ServerMins | Displays the number of minutes from 0 to 60 the server has been online, carries over to $ServerHours. |
| $ServerSecs | Displays the number of seconds from 0 to 60 the server has been online, carries over to $ServerMins. |
| $ServerKBup | Displays the total number of kilobytes uploaded. |
| $ServerKBdown | Displays the total number of kilobytes downloaded. |
| $ServerFilesUp | Displays the total number of files uploaded. |
| $ServerFilesDown | Displays the total number of files downloaded. |
| $ServerFilesTot | Displays the total number of files transferred, essentially ($ServerFilesUp + $ServerFilesDown). |
| $LoggedInAll | Displays the total number of established sessions. |
| $ServerUploadAvgKBps | Displays the average upload rate in KB/s. |
| $ServerDownloadAvgKBps | Displays the average download rate in KB/s. |
| $ServerAvg | Displays the average data transfer rate (uploads and downloads) in KB/s. |
| $ServerUploadKBps | Displays the current upload transfer rate in KB/s. |
| $ServerDownloadKBps | Displays the current download transfer rate in KB/s. |
| $ServerKBps | Displays the current aggregate data transfer rate in KB/s. |
| $ServerSessions24HPlusOne | Displays the total number of sessions in the past 24 hours plus one additional session. |
| $ServerSessions24H | Displays the total number of sessions in the past 24 hours. |
Domain statistics
| $DomainKBup | Displays the total number of kilobytes uploaded. |
| $DomainKBdown | Displays the total number of kilobytes downloaded. |
| $DomainFilesUp | Displays the total number of files uploaded. |
| $DomainFilesDown | Displays the total number of files downloaded. |
| $DomainFilesTot | Displays the total number of files transferred, essentially ($DomainFilesUp + $DomainFilesDown). |
| $DomainLoggedIn | Displays the total number of sessions currently connected. |
| $DomainUploadAvgKBps | Displays the average upload rate in KB/s. |
| $DomainDownloadAvgKBps | Displays the average download rate in KB/s. |
| $DomainAvg | Displays the average aggregate data transfer rate (uploads and downloads) in KB/s. |
| $DomainUploadKBps | Displays the current upload transfer rate in KB/s. |
| $DomainDownloadKBps | Displays the current download transfer rate in KB/s. |
| $DomainKBps | Displays the current aggregate data transfer rate in KB/s. |
| $DomainSessions24HPlusOne | Displays the total number of sessions in the past 24 hours plus one additional session. |
| $DomainSessions24H | Displays the total number of sessions in the past 24 hours. |
User statistics
This data applies to all sessions attached to the user account.
| $UserKBUp | Displays the total number of kilobytes uploaded. |
| $UserKBDown | Displays the total number of kilobytes downloaded. |
| $UserKBTot | Displays the total amount of kilobytes transferred. |
| $UserLoggedIn | Displays the total number of sessions. |
| $UserUploadAvgKBps | Displays the average upload rate in KB/s. |
| $UserDownloadAvgKBps | Displays the average download rate in KB/s. |
| $UserAvg | Displays the average aggregate data transfer rate (uploads and downloads) in KB/s. |
| $UserUploadKBps | Displays the current upload transfer rate in KB/s. |
| $UserDownloadKBps | Displays the current download transfer rate in KB/s. |
| $UserKBps | Displays the current aggregate data transfer rate in KB/s. |
| $UserSessions24HPlusOne | Displays the total number of sessions in the past 24 hours plus one additional session. |
| $UserSessions24H | Displays the total number of sessions in the past 24 hours. |
This data applies to the most recently completed successful data transfer.
| $TransferBytesPerSecond | Displays the effective (compressed) transfer rate in bytes/s. |
| $TransferKBPerSecond | Displays the effective (compressed) transfer rate in KB/s. |
| $TransferBytes | Displays the effective (compressed) number of bytes transferred, formatted for display, for example, 32,164. |
| $NoFormatTransferBytes | Displays the effective (compressed) number of bytes transferred, unformatted, for example, 32164. |
| $TransferKB | Displays the effective (compressed) number of kilobytes transferred, formatted for display. |
| $ActualTransferBytesPerSecond | Displays the actual (uncompressed) transfer rate in bytes/s. |
| $ActualTransferKBPerSecond | Displays the actual (uncompressed) transfer rate in KB/s. |
| $ActualTransferBytes | Displays the actual (uncompressed) number of bytes transferred, formatted for display, for example, 32,164. |
| $NoFormatActualTransferBytes | Displays the actual (uncompressed) number of bytes transferred, unformatted, for example, 32164. |
| $ActualTransferKB | Displays the actual (uncompressed) number of kilobytes transferred, formatted for display. |
| $CompressionRatio | Displays the ratio of compression for the transfer expressed as a percentage of the expected amount of data transferred. For example, a value of 100.00 means the data could not be compressed. A value of 200.00 means the data compressed to half its original size. |
| $CommandResult | Displays the command result in the return response of any command, providing information such as compression level, and so on. (FTP only) |
| $Command | Displays the FTP command name, such as RETR, MODE, or SIZE. (FTP only) |
| $Parameters | Displays the parameters used for the command, such as "Z" for the MODE command indicating the compression type, a file name for the STOR command, and so on. (FTP only) |
| $DataMode | Displays the data transfer mode for an FTP data transfer, which may be either BINARY for binary mode transfers or ASCII for ASCII mode data transfers. (FTP only) |
| $CurrentCompressedTransferBytes | Displays the current effective (compressed) number of bytes transferred so far, unformatted, for example, 32164. (FTP only) |
| $CurrentUncompressedTransferBytes | Displays the current actual (uncompressed) number of bytes transferred so far, unformatted, for example, 32164. (FTP only) |
Date/Time
| $Date | Displays the current date according to the Serv-U File Server, in the local date format of the system. |
| $Time | Displays the current time according to the Serv-U File Server, in the local time format of the system. |
| $Day | Displays the day of the month. |
| $Month | Displays the two-digit numeric month. |
| $TextMonth | Displays the text version of the month. |
| $Year | Displays the four-digit year. |
| $2DigitYear | Displays the two-digit year. |
| $Hour | Displays the hour (24-hour clock). |
| $Minute | Displays the minute. |
| $Second | Displays the second. |
Server settings
| $MaxUsers | Displays the maximum number of sessions allowed to log in, which could be limited by the license. |
| $MaxAnonymous | Displays the maximum number of anonymous users allowed to log in. |
Session information
This information applies to the current session.
| $Name | Displays the login ID of the attached user account. |
| $LoginID | Displays the session's login ID, operates like $Name. $Name can refer to the login ID for target user accounts but $LoginID refers only to the login ID of the session. |
| $IP | Displays the client IP address. |
| $IPName | Displays the reverse DNS name as obtained by performing a reverse DNS lookup on $IP. |
| $Dir | Displays the session's current directory. |
| $Disk | The local drive letter being accessed. |
| $DFree | Displays the amount of free space on $Disk in MB. |
| $FUp | Displays the total number of files uploaded. |
| $FDown | Displays the total number of files downloaded. |
| $FTot | Displays the total number of files transferred, essentially ($FUp + $FDown). |
| $BUp | Displays the total number of kilobytes uploaded. |
| $Bdown | Displays the total number of kilobytes downloaded. |
| $BTot | Displays the total number of kilobytes transferred. |
| $TConM | Displays the total number of minutes the session has been connected. |
| $TConS | Displays the number of seconds from 0 to 60 that the session has been connected, carries over to $TconM. |
| $RatioUp | Displays the 'upload' portion of the applied ratio, "N/A" if not in use. |
| $RatioDown | Displays the 'download' portion of the applied ratio, "N/A" if not in use. |
| $RatioType | Displays the type of ratio being applied, either per session or per user. |
| $RatioCreditType | Displays the type of ratio credit granted for transfers, either per bytes or per complete file. |
| $RatioCredit | Displays the current transfer credit for the applied ratio, either megabytes or complete files. |
| $QuotaUsed | Displays how much disk quota is currently being used in MB, "Unlimited" if no quota is in use. |
| $QuotaLeft | Displays how much disk quota is available in MB, "Unlimited" if no quota is in use. |
| $QuotaMax | Displays the maximum amount of disk space that can be used in MB, "Unlimited" if no quota is in use. |
| $CurrentDirMaxSize | Displays the maximum size of the current directory in MB. If the directory has no size limit, the variable will return "unlimited". If permission is denied in the directory, or any other error occurs, the value "N/A" will be returned. |
| $SessionID | Displays the unique session ID of the current session. Session IDs are counted from 000001, and the counter is reset each time Serv-U is started. |
| $Protocol | Displays the current protocol being used (FTP, FTPS, HTTP, HTTPS, or SFTP (SSH2)). |
| $UserDomainName | Uses either the logged in domain name or the user's parent domain name. A blank name is returned if the user is a global server user that is not logging in. |
| $DomainName | Displays the current domain that the session is logged into. |
| $DomainDescription | Displays the description of the current domain that the session is logged into. |
| $TimeRemaining | Displays the time remaining when blocking an IP address for an amount of time (available only in Event notifications). |
| $LocalHomeDirectory | Displays the local home directory. It should only be used for events that need this specific information such as user creation. |
| $UserEmailAddress | Displays the user's email address. |
| $FullName | Displays the user's full name as entered into the "Full Name" field for a user account. |
| $SpaceFullName | The same as "$FullName" with the addition of a space before the user's full name. Blank (no space or name) when the user's full name is empty. |
| $FullNameSpace | The same as "$FullName" with the addition of a space after the user's full name. Blank (no space or name) when the user's full name is empty. |
| $Port | Displays the port number of the client. |
| $ServerIP | Displays the IP address of the server. |
| $ServerPort | Displays the port number of the server. |
Using the $IPName variable inside of an event or sign-on message can cause a slight delay while the reverse DNS information for $IP is retrieved.
File information
This information applies to the last remotely accessed file, which is not necessarily the last transferred file.
| $PathName | Retrieves the full remote path. |
| $FileName | Retrieves only the file name from $PathName. |
| $FileSize | Retrieves the size, in bytes, of the file from $FileName. |
| $FileSizeFmt | Displays a formatted version of the file size, containing the thousands separator (comma or period depending on the computer's regional settings). |
| $FileSizeKB | Displays a formatted floating point value representing the file size in KB. |
| $LocalPathName | Retrieves the fully qualified local path name for an operation, as it relates to Windows. For example C:\Temp\File.fid instead of /Temp/file.fid. |
| $LocalFileName | Retrieves the name of the file as it is stored on the local computer. See $LocalPathName for details. |
| $OldLocalPathName | Same as $LocalPathName, but contains the path prior to renaming. |
| $OldLocalFileName | Same as $LocalFileName, but contains the file name prior to renaming. |
| $OldPathName | Retrieves the remote path name prior to renaming. |
| $OldFileName | Retrieves the remote file name prior to renaming. |
Current activity
| $UNow | Displays the current number of sessions on the Serv-U File Server. |
| $UAll | Displays the total number of sessions that have connected to the Serv-U File Server since it was last started. |
| $U24h | Displays the total number of sessions that have connected to the Serv-U File Server in the last 24 hours. |
| $UAnonAll | Displays the current number of sessions attributed to the anonymous user on the Serv-U File Server. |
| $UAnonThisDomain | Displays the current number of sessions attributed to the anonymous user on the connected domain. |
| $UNonAnonAll | Displays the current number of sessions not attributed to the anonymous user on the Serv-U File Server. |
| $UNonAnonThisDomain | Displays the current number of sessions not attributed to the anonymous user on the connected domain. |
| $UThisName | Displays the current number of sessions attributed to the connected user account. |
FileShare
| $FileShareToken | Used in download/upload events. |
| $FileShareExpires | Displays the link expiration date. |
| $FullName | Displays the Serv-U username of the user who shared the file. |
| $FileShareTokenURL | Displays the fileshare URL. |
| $FileShareComments | Displays an optional message. |
