Documentation forServ-U File Server
Legacy Serv-U Web Client Pro transfer pane
From Serv-U 15.3, Serv-U includes a new and improved web client. However, the Legacy Serv-U Web Client is still available. Click here to access the documentation for the new client.
The transfer pane provides a comprehensive view of all active file operations in Web Client Pro, grouped together according to operations that began at the same time. A set of operations is referred to as an operation group, and is named according to the type of action (Download, Upload, Delete) and which order it occurred in. The transfer pane provides the following information about each transfer:
Operation
The status of the operation.
Name
The name of the file being uploaded, downloaded, or deleted.
Status
The current speed of the operation.
Completion
The estimated time until the completion of the operation.
Source path
The full path to the source file. This may be a local path (such as C:\files\myfile.txt), or a remote path (such as /files/myfile.txt).
Destination path
The full path to the destination file. It operates the same way as the source path, showing the destination of the file.
