Serv-U server settings
On the
| Connection Settings | |
Block users who connect more than 'x' times within 'y' seconds for 'z' minutes |
Also known as anti-hammering, enabling this option is a method of preventing brute force password guessing systems from using dictionary style attacks to locate a valid password for a user account. Using strong, complex passwords defeats most dictionary attacks. However, enabling this option ensures that Serv-U does not waste time processing connections from these illegitimate sources. When configuring this option, ensure that there is some room for legitimate users to correct an incorrect password before they are blocked. When enabled, this option temporarily blocks (for the specified number of minutes) IP addresses that fail to successfully login (after the specified number of attempts within the specified number of seconds). IP addresses blocked in this way can be viewed in the appropriate IP access rules tab. A successful login resets the counter that is tracking login attempts. |
Hide server information from SSH identity |
When the connection has been established, the server sends identification information to the client. Normally, this information includes the server name and version number. Enable this option to prevent the information from being provided to the client. |
| Custom HTTP Logo, Login Page Text & Title Settings | |
| HTTP Login Title Text (no HTML) | Enter a text-only title to appear when a HTTP client logs into the file server. |
| Custom Logo Path |
To use your own custom logo, create a 400 x 100 pixel graphic and enter or navigate to its location. An error message will be displayed if this criteria is not met. To reset to original Serv-U log, select <<Inherit default value>> from the drop-down menu. |
| HTTP Login Page Text |
Enter the text to be displayed on the HTTP login page. This text can be HTML-formatted, including links, images, and standard formatting like italics, bold, underline, alignment and more. |
| HTTP Client Interface Background (CSS Only) |
MFT only. Enter a CSS background style for the Serv-U Client landing page. The format is:
The %CUSTOM_HTML_DIR% must be used in conjunction with the Custom HTML settings. Custom HTML must be enabled and a Custom HTML Container Directory must be specified. The following examples provide a reference:
| Network settings | |
Auto-configure firewall through UPnP (Windows Only) |
When enabled, Serv-U automatically configures the necessary port forwards in your UPnP-enabled network device (usually a router) so that the file server is accessible from outside your network. This is particularly useful in enabling PASV mode FTP data transfers. |
Packet time-out |
Specifies the timeout, in seconds, for a TCP packet transfer. Only very slow networks experiencing high levels of latency may need to change this value from the default 300 seconds. |
PASV Port Range |
Specifies the inclusive range of ports that Serv-U should use for PASV mode data transfers. Serv-U normally allows the operating system to assign it a random port number when opening a socket for a PASV mode data transfer. This attribute accommodates routers or firewalls that need to know a specific range of ports in advance by restricting the PASV port range of Serv-U to a known range. A range of 10 ports is sufficient for the busiest of file servers. Some NAT routers work differently and may require a larger port range. If Serv-U and clients have troubles listing directories or transferring files, try increasing the port range here and on your router. |
| Require matching peer IP address for control and data connections | To avoid the risk of FTP bounce attacks, check this box to ensure the peer address of the control connection matches that of the data connection. If they do not match, the transfer will be disallowed. If you are making server-to-server transfers you will need to leave this box unchecked. |
Other settings |
Integration Library |
For information about writing an Integration DLL or Shared Library, see the Serv-U Integration Sample DLL in the Serv-U Integration Sample DLL sub-directory. The Integration API is documented in this sample. |
Files listed by clicking the Ratio Free Files button are exempt from transfer ratio limitations on file transfers. Ratio Free Files specified at the server or domain level are inherited by all their user and group accounts. |
Change Admin Password |
The Serv-U Management Console can be password protected when it is launched by double-clicking on the Serv-U system tray icon. When the Management Console is running in this way, the option to change the password becomes available. By default, there is no admin password. |
