Domain settings
On the
| Connection Settings | |
Block users who connect more than 'x' times within 'y' seconds for 'z' minutes |
Also known as anti-hammering, enabling this option is a method of preventing brute force password guessing systems from using dictionary style attacks to locate a valid password for a user account. Using strong, complex passwords defeats most dictionary attacks. However, enabling this option ensures that Serv-U does not waste time processing connections from these illegitimate sources. When configuring this option, ensure that there is some room for legitimate users to correct an incorrect password before they are blocked. When enabled, this option temporarily blocks (for the specified number of minutes) IP addresses that fail to successfully login (after the specified number of attempts within the specified number of seconds). IP addresses blocked in this way can be viewed in the appropriate IP access rules tab. A successful login resets the counter that is tracking login attempts. |
Hide server information from SSH identity |
When the connection has been established, the server sends identification information to the client. Normally, this information includes the server name and version number. Enable this option to prevent the information from being provided to the client. |
| Custom HTTP Logo, Login Page Text & Title Settings | |
| HTTP Login Title Text (no HTML) | Enter a text-only title to appear when a HTTP client logs into the file server. |
| Custom Logo Path |
To use your own custom logo, create a 400 x 100 pixel graphic and enter or navigate to its location. An error message will be displayed if this criteria is not met. To use the logo selected for the server level, select <<Inherit default value>> from the drop-down menu. |
| Use inherited default message | Select to use the sever level message. |
| HTTP Login Page Text |
Enter the text to be displayed on the HTTP login page. This text can be HTML-formatted, including links, images, and standard formatting like italics, bold, underline, alignment and more. |
| HTTP Client Interface Background (CSS Only) |
MFT only. Enter a CSS background style for the Serv-U Client landing page. The format is:
The %CUSTOM_HTML_DIR% must be used in conjunction with the Custom HTML settings. Custom HTML must be enabled and a Custom HTML Container Directory must be specified. The following examples provide a reference:
Other settings |
Integration Library |
For information about writing an Integration DLL or Shared Library, see the Serv-U Integration Sample DLL in the Serv-U Integration Sample DLL sub-directory. The Integration API is documented in this sample. |
Files listed by clicking the Ratio Free Files button are exempt from transfer ratio limitations on file transfers. Ratio Free Files specified at the server or domain level are inherited by all their user and group accounts. |
