Documentation forServ-U File Server
Legacy Serv-U Web Client Pro operation management
From Serv-U 15.3, Serv-U includes a new and improved web client. However, the Legacy Serv-U Web Client is still available. Click here to access the documentation for the new client.
The Web Client Pro toolbar includes all functions needed to manage ongoing operations in the transfer pane. The following section contains the list of these functions.
Show in Folder
Launches the default file explorer of the operating system and navigates to the download's target directory of the selected row.
Open File
Launches the operating system's default program for the download's target file of the selected row.
Stop After File Completes
Waits for the current operation to finish, then stops all upcoming transfers and awaits user input.
Skip File
Skips the currently uploading or downloading file, and then moves on to the next operation in the queue.
Pause
Pauses the current operation and the rest of the operation queue.
Resume
Resumes the current transfer operation and the rest of the operation queue.
Start
Starts an operation queue that has been stopped completely.
Restart/Relist
Restarts a failed operation or relists a directory listing operation that has failed.
Remove
Removes a file or operation group from the transfer pane.
Remove Completed
Removes completed operations only from the transfer pane.
Remove Canceled
Removes canceled operations only from the transfer pane.
Remove Skipped
Removes skipped operations only from the transfer pane.
Remove Paused
Removes paused operations only from the transfer pane.
Remove Waiting
Removes waiting operations only from the transfer pane.
Remove Stopped
Removes stopped operations only from the transfer pane.
Remove All
Removes all completed, canceled, skipped, paused, waiting, and stopped operations from the transfer pane.
Settings
Provides access to the configuration options for Web Client Pro.
About
Displays version and developer information about Web Client Pro.
