Serv-U global directories
This tab enables you to configure the basic directory structure available to all users of the file server, including default directory access rules, virtual paths and file management rules.
Default directory access rules, virtual paths and file management rules can also be defined at the domain, groups and user level.
| Directory Access | Server directory access rules are global rules defining the files and directories to which all users on this server have access. |
| Virtual Paths | Virtual paths are used to link a physical path outside of the directory structure of the user's home directory into the directory listings received by that user. |
| File Management | File Management Rules allow Serv-U to automatically remove or archive files from your File Server. |
