NCM macros (variables)
NCM provides the following types of macros (also called variables). All NCM macros are enclosed in ${ }. For example, the macro for system name is ${SysName}. Macros are not case-sensitive.
Global macros
The values for global macros are specified by global device defaults. The value for a global macro is the same for all nodes.
You can also create custom global macros.
| Macro | Inserts the value of this Global Device Defaults field |
| ${GlobalUserName} | Username |
| ${GlobalPassword} | Password |
| ${GlobalEnableLevel} | Enable Level |
| ${GlobalEnablePassword} | Enable Password |
| ${GlobalExecProtocol} | Execute Commands and Scripts |
| ${GlobalConfigRequestProtocol} | Config Request |
| ${GlobalConfigTransferProtocol} | Transfer Configs |
| ${GlobalTelnetPort} | Telnet Port |
| ${GlobalSSHPort} | SSH Port |
Node macros
Node macros point to a column in the NCM_Nodes table. The value of a node macro is unique for each node. The following table lists the NCM_Nodes table column that supplies the value for each macro.
| Macro | Inserts this value |
| ${AgentIP} |
The IP address of the node, from one of these columns:
| ${Caption} |
The name used to identify the node in the SolarWinds Platform, from the During discovery, this value is populated with the host name (if available) or the DNS domain name. You can change it by editing the node property Name. This value is not updated when the node is rediscovered. |
| ${SystemName}
${SysName} |
The host name of the node, if it can be polled during discovery. This value is updated when the node is rediscovered. The value is one of the following:
| ${SystemLocation} ${SysLocation} |
The node location, which is obtained from the device via SNMP polling. This value is stored in the SysLocation column. |
| ${SystemContact} ${SysContact} |
The node contact, which is obtained from the device via SNMP polling. This value is from the SysContact column. |
| ${Description} ${SysDescr} ${SystemDescription} ${SysDescription} |
The node description, from the SysDescr column. |
| ${SCPStorageAddress} |
The IP address or host name of the NCM SCP server, from one of the following columns:
| ${StorageAddress} |
The IP address or host name of the NCM TFTP server, from one of the following columns:
| ${SCPServerUserName} | The user name that NCM uses to access the SCP server, from the Settings.SCPUserName column. |
| ${PCAddress}
${ServerIP} ${IPAddress} ${TFTPServer} ${LocalIP} |
The IP address of the SolarWinds Platform primary server, from the EngineIP column. |
| ${HostName}
${LocalHostName} |
The host name of the SolarWinds Platform primary server, from the EngineServerName column. |
| ${TransferProtocol} | The transfer protocol used during an indirect transfer, from the TransferProtocol column. |
Transfer macros
Transfer macros are used when NCM uploads or downloads configuration files.
| ${ConfigType} | The type of configuration (for example, running or startup). |
| ${StorageFileName} | The name generated by NCM for the downloaded configuration file. |
| ${ConfigText} |
In a direct upload operation, the config to be uploaded to the device. |
Command macros
Device template commands are used to execute commands on devices. Device templates define the Name and Value for each device command. For example, EnterConfigMode is a command name, and the value is the command required to enter config mode for a specific device type. For a description of all device template commands, see NCM device template commands.
When a command is defined in a device template, you can include the command as a macro within a script. To do so, format the command Name as a macro (for example, ${EnterConfigMode}).
Device command templates for each device type can define different Values for commands with the same Name. For example, the value of EnterConfigMode is config terminal for Cisco IOS devices, but it is configure for HP Procurve switches. When you use a command macro in a script instead of the actual command, you can use the same script for multiple device types.
Date and time macros
Date and time macros are replaced with current date or time.
| Macro | Inserts this value | Examples |
| ${DateTime} ${Date Time} ${Date/Time} |
Local date and time in short date and local time format (the Short Date and Short Time format defined in the Windows Control Panel) | 10-29-2026 2-55 PM |
| ${Date} ${ShortDate} ${Short Date} |
Date in short date format | 10-29-2026 |
| ${MediumDate} ${Medium Date} |
Date in medium date format | 29-Oct-26 |
| ${LongDate} ${Long Date} |
Date in long date format | Tuesday, October 29, 2026 |
| ${Time} ${ShortTime} ${Short Time} |
Time in short time format | 14-55 |
| ${MediumTime} ${Medium Time} |
Time in medium time format | 02-55 PM |
| ${LongTime} ${Long Time} |
Time in long time format | 2-55-48 PM |
| ${DOW} ${Day Of Week} ${DayOfWeek} |
Day of the week, spelled out | Tuesday |
| ${AbreviatedDOW} ${Abreviated Day Of Week} ${AbreviatedDayOfWeek} |
Abbreviated day of the week | Tue |
| ${D} ${Day} |
One- or two-digit day of the month |
5 |
| ${DD} | Two-digit day of the month, with a leading zero if needed |
05 |
| ${MMMM} ${MonthName} $Month Name} |
Name of the month, spelled out | October |
| ${MMM} ${AbreviatedMonth} ${Abreviated Month} |
Abbreviated name of the month | Oct |
| ${Month}
${M} |
One- or two-digit month number |
5 |
| ${MM} | Two-digit month number, with a leading zero if needed |
05 |
| ${DayOfYear} ${Day Of Year} |
Number of the day of the year | 302 |
| ${Year2} ${Year2} ${YY} |
Two-digit year | 26 |
${Year4} |
Four-digit year |
2026 |
| ${H} ${Hour} |
One- or two-digit hour |
02 |
| ${HH} | Two-digit hour, with a leading zero if needed |
02 |
| ${NN} ${Minute} |
Two-digit minute, with a leading zero if needed |
05 |
| ${N} | One- or two-digit minute |
5 |
| ${SS} ${Second} |
Two-digit second, with a leading zero if needed |
05 |
| ${S} | One- or two-digit second |
5 |
| ${AMPM} ${AM/PM} |
AM or PM | PM |
Keystroke macros
Keystroke macros send keystrokes to menu-based or CLI devices. For example, ${DownArrow} simulates sending a Down Arrow keystroke to the device.
| Macro | Sends these characters |
| ${CTRL+@} | CTRL+@ |
${CTRL+A} |
CTRL + A |
| ${CTRL+B} | CTRL+B |
| ${CTRL+C} | CTRL+C |
| ${CTRL+D} | CTRL+D |
| ${CTRL+E} | CTRL+E |
| ${CTRL+F} | CTRL+F |
| ${CTRL+G} | CTRL+G |
| ${CTRL+H} | CTRL+H |
| ${CTRL+I} | CTRL+I |
| ${CTRL+J} | CTRL+J |
| ${CTRL+K} | CTRL+K |
| ${CTRL+L} | CTRL+L |
| ${CTRL+M} | CTRL+M |
| ${CTRL+N} | CTRL+N |
| ${CTRL+O} | CTRL+O |
| ${CTRL+P} | CTRL+P |
| ${CTRL+Q} | CTRL+Q |
| ${CTRL+R} | CTRL+R |
| ${CTRL+S} | CTRL+S |
| ${CTRL+T} | CTRL+T |
| ${CTRL+U} | CTRL+U |
| ${CTRL+V} | CTRL+V |
| ${CTRL+W} | CTRL+W |
| ${CTRL+X} | CTRL+X |
| ${CTRL+Y} | CTRL+Y |
| ${CTRL+Z} | CTRL+Z |
| ${CTRL+[} | CTRL+[ (Equivalent to pressing the Esc key) |
| ${CTRL+\} | CTRL+\ |
| ${CTRL+]} | CTRL+] |
| ${CTRL+CTRL} | CTRL+CTRL |
| ${CTRL+ } | CTRL+ |
| ${UpArrow} | Up Arrow |
| ${DownArrow} | Down Arrow |
| ${RightArrow} | Right Arrow |
| ${LeftArrow} | Left Arrow |
| ${CR} | Carriage return |
| ${CRLF} |
Carriage return and line feed combination: \r\n |
Prompt detection and delay macros
The following macros can be included in scripts.
| Macro | Description |
| ${DisablePromptDetection} ${EnablePromptDetection} |
By default, NCM waits for the device to send a command mode prompt before it sends the next command. If a device does not send a command mode prompt immediately after each command, you can include the following macros in a script to turn off prompt detection for a block of commands in order to improve the performance of the script.
The Use these macros to surround a specific group of commands. Always use |
| ${Delay:nn} |
In a command script, use the Delay macro to specify the number of seconds that NCM should wait before it sends the next command. Use this macro when the first command will take some time to complete. The following example waits 20 seconds before it sends Command2:
| ${NewPromptRegEx:regEx} |
If a device's command mode prompt changes frequently and the
Policy rule remediation script macros
These macros are used in policy rule remediation scripts to insert all or part of the config line that starts the macro block.
In policy rule remediation scripts that meet the conditions described below, NCM automatically the ${ConfigBlockStartLine} macro. You can choose to replace the ${ConfigBlockStartLine} macro with the ${ConfigBlockMatchValue} macro. However, do not manually add these macros to other types of remediation scripts.
This macro is automatically added to the beginning of a policy rule remediation script when the following conditions are met:
This macro inserts the entire starting line of the config block. |
${ConfigBlockMatchValue}. |
To insert only the string that matches the entry in the Config block start box, replace the For example, if the config line is:
Where can macros be used?
You can use macros in the following operations.
| NCM functionality | Macros you can use |
| Connection profiles that enable NCM to connect to a node |
| Policy compliance rules |
| Command scripts |
NCM jobs |
| Template for naming archived config files |
| Device templates |
| Real-time change detection email notification options |
| Firmware upgrade templates |
| Alerts | |
The SWIS verb NodeInvoker.ParseMacros |
