Import and export device templates
If you have multiple SolarWinds Platform servers, you can share device templates between them. You can export a device template as an XML file, and then import it to another SolarWinds Platform server.
You can also share device templates on THWACK.
Export a device template
- Click Settings > All Settings.
- Under Node & Group Management, click Manage Device Templates.
Select a template, and click Export As File.
The XML file is saved in your
\Downloadsdirectory with the.ConfigMgmt-Commandsextension.
Import a device template
You can import a device template that was previously exported as a file.
- Click Import.
- Click Choose File, browse to the template, and select it.
- Click Submit.
