Documentation forHybrid Cloud Observability Advancedand Network Configuration Manager
Access NCM firmware vulnerability settings
NCM imports the firmware vulnerability warnings provided by National Institute of Standards and Technology (NIST) and correlates vulnerabilities with managed nodes. Use the firmware vulnerability settings to specify when the matching logic runs or change the default import locations or alert threshold.
  1. Click Settings > All Settings.
  2. Under Product Specific Settings, click NCM Settings.
  3. Under Advanced, click Firmware Vulnerability Settings.
  4. Adjust settings for Vulnerability Search, Vulnerability Data Import, and Vulnerability Alerting.
    If you add or change the URLs under Vulnerability Data Import Settings, you can test the URLs to verify that the correct data will be downloaded.
  5. Click Submit.
