Documentation forNetwork Configuration Manager
Import and export firmware upgrade templates
If you have multiple SolarWinds Platform servers, you can share firmware upgrade templates between them. You can export a firmware upgrade template as an XML file, and then import it to another SolarWinds Platform server.
You can also share firmware upgrade templates on THWACK.
Export a firmware upgrade template
  1. Click Settings > All Settings.
  2. Under Product Specific Settings, click NCM Settings.
  3. In the Firmware Upgrade section, click Firmware Upgrade Templates.
  4. Select a template, and click Export As File.
    The XML file is saved in your \Downloads directory. The file name is based on the template name.
Import a firmware upgrade template
You can import a firmware upgrade template that was previously exported as a file.
  4. Click Import.
  5. Click Choose File, browse to the template, and select it.
  6. Click Submit.
