Configure nodes to use user-level login credentials for NCM connections
When NCM uses user-level login credentials to connect to a node, the login credentials are associated with a SolarWinds Platform user account rather than the node. Each NCM user defines a set of credentials that NCM can connect with. Each set of login credentials is associated with the SolarWinds Platform account under which it was defined:
When a user logs in with a SolarWinds Platform account and performs an action in NCM, NCM connects to the node with the user-level login credentials associated with that SolarWinds Platform account.
When NCM processes a job, it connects to the node with the user-level login credentials associated with the SolarWinds Platform account of the user who created or most recently edited the job definition.
The access provided by user-level login credentials can vary.
For information about other configuration options, see Options for specifying NCM connection information.
To configure user-level login credentials, complete the following tasks.
Gather information
Before you begin:
- Locate the login credentials for the node you want to add to NCM.
- Determine whether NCM communicates with the device by way of Telnet or SSH.
- Identify the Telnet or SSH ports used for communication.
Enable user-level login credentials in NCM
User-level login credentials are not enabled by default. Complete the following steps to enable them.
- Click Settings > All Settings.
- Under Product Specific Settings, click NCM Settings.
- Under Security, click Security.
- Under Device Login & User Account Credentials, select Individual - User Level.
- Click Submit.
Define user-level login credentials
Each NCM user must define the credentials that NCM will use to log in to devices. When credentials change (for example, when passwords are updated on the authentication server), each user must update the user-level login credentials in NCM.
- Log in to the SolarWinds Platform Web Console with the SolarWinds Platform user account that will be associated with this set of user-level login credentials.
- Under Security, click Manage User Level Login Credentials.
- Enter the user name and password that NCM should use to access the network device.
Under Enable Level, select
enableif NCM must enter a command to provide a higher level of access on the network devices. On some devices, this command is required to allow NCM to back up configs, upload changed configs, and run certain scripts.If a command is required, but the command is not
enable, do the following:-
Select
enablein the connection profile. -
In the device template that defines the device-specific commands used to perform actions on that device, include the following:
<Command Name="EnableCommand" Value="commandForMyDevice"/>where
commandForMyDeviceis the command entered on your device (for example,super).
If the NCM account has the privileges it needs without having to enter a command such as
enable, then make sureenableis not selected in the connection profile. -
- If you selected
enable, enter the password for it. - Click Submit.
Assign user-level login credentials to nodes
- Choose Settings > Manage Nodes.
- Select one or more nodes.
- Click Edit Properties.
- Scroll down to Manage node(s) with NCM, and verify that Yes is selected.
- If multiple nodes are selected, click the Connection Profile check box to enable editing.
For Login Credentials, select User.
The user name, password, enable level, and enable level password can no longer be specified because they are defined by the user account.
If necessary, change the values selected for protocols and ports.
If the connection profile uses global variables, you can review or change the value of the global variables.
To override global variables, update any of the following:
- For Execute Scripts Using, choose the protocol that NCM should use to execute commands and scripts.
For Request Configs Using, choose the protocol that NCM should use to log in to a device and request a config transfer.
For more information about Config Request and Transfer Config options, see Protocols NCM uses to transfer configurations.
- For Transfer Configs using, choose the protocol that NCM should use to upload and download configs.
- Set the Telnet and SSH ports to the ports allowed on your network.
Click Test to test the connection.
If the test fails, click Advanced Test to open the CLI Connection Analyzer dialog. Review the connection settings on this dialog and make changes if needed.
To run the test again, click Test connection. The CLI Test result page shows the results as well as log file entries to help you troubleshoot any issues.
Click Submit.
