Schedule regular backups of network config files
To ensure that network configs are backed up on a regular basis, NCM includes the Nightly Config Backup job, which downloads the config files for all devices every night. This job is enabled by default, so it runs automatically. You can use this job to back up your configs, or you can create a custom backup job to meet the needs of your organization.
SolarWinds recommends the following best practices:
- For configurations that change frequently, schedule a daily backup of the config.
- At a minimum, back up configs weekly.
Config backups are stored in the SolarWinds Platform database and (optionally) the config archive location.
See the following sections:
About the default NCM backup jobs
NCM provides two default jobs to back up your configurations: the Nightly Config Backup job and the Weekly Config Backup job. Determine whether one of the default jobs meets your needs, or whether you need to create a custom job.
SolarWinds does not recommend enabling both the Nightly Config Backup job and the Weekly Config Backup job.
The Nightly Config Backup job is enabled by default and runs automatically. It downloads the config files for all devices every night.
By default, the Nightly Config Backup job:
Runs at 2:00 AM every day
Downloads the Running and Startup configs from all nodes
The job runs only on devices that support the selected config types. If your devices support different config types, you can configure multiple backup jobs that target different groups of devices. For example, one job could target only Palo Alto devices and back up the Device State.
Saves the results to a job log
Does not send email notification when it runs
Saves configs whether or not they changed
Does not send notifications if configs have changed
The Weekly Config Backup job is also available, but it is not enabled by default. If you prefer to back up configs weekly instead of daily, you can enable this job and disable the Nightly Config Backup job.
By default, the Weekly Config Backup job:
Runs at 2:00 AM every Sunday
No nodes are selected by default
Saves running configs
Create a custom backup job
You can create one or more custom backup jobs to meet the needs of your organization. You might need to create multiple jobs that run against different sets of devices.
SolarWinds does not recommend running multiple backup jobs against the same devices.
It is possible to edit the Nightly Config Backup job or the Weekly Config Backup job to change the default settings. However, because changes to the default jobs cannot be reverted, SolarWinds recommends that you create a custom job by copying one of the default jobs and editing the copy.
- Click My Dashboards > Network Configuration > Jobs.
- Select the Nightly Config Backup job or the Weekly Config Backup job.
- Click Duplicate Job.
- Specify a unique name. For example, include the name of your organization in the job name.
Specify when the job runs:
To run the job once or on a simple schedule, select Basic. Click the tab that identifies how frequently the job runs, and then specify the start time and (if needed) the day(s).
To create a more complex schedule, select Advanced and then use the five fields to create a CRON expression.
- In the Comments box, include the reason for your changes, and then click Next.
Specify which devices this job targets, and click Next.
All Nodes is selected by default. Leave this selection to back up configs from all devices added to NCM.
If you do not want this job to run on all devices, select Dynamic Selection and specify the criteria used to select the devices.
For example, to create a job that runs on all Palo Alto devices, select
Vendor is Palo Alto Networks. You could also create a second job to run on all other devices by selectingVendor is not Palo Alto Networks. Click View Selected Nodes to verify that your criteria targets the expected nodes.
Alternatively, you can choose Select Nodes and add specific nodes. However, you must remember to update the job definition whenever devices are added to the network.
- Select an email notification option, and click Next. If you click Email Results, the default email notification and SMTP server settings are populated. These settings can be overridden in each job.
- Select the configuration types you want to download, and specify whether you want to back up configs only if they have changed since the last backup.
- If you want to be notified when a config has changed, select the send config change notifications. Then click Next.
Review the settings for the job, and click Finish.
The job is enabled by default.
- To avoid running both your custom job and the default job, disable the default job.
Enable or disable a job
- In the Jobs List, select the job or jobs you want to enable or disable.
- Click Enable or Disable.
Determine if the configs on all devices are backed up
Use the Config Summary page to identify devices whose configs have not been backed up since the last update.
- Click My Dashboards > Network Configuration > Config Summary.
Locate one of the following widgets:
If you are using the classic Config Summary dashboard, locate the Overall Devices Backed Up vs. Not Backed Up widget.
A yellow slice indicates that the configs on one or more devices have not been backed up since the last update.
If you are using the modern Config Summary dashboard, locate the Backups widget.
The widget shows the number of configs whose backup job failed and the number that are not configured to be backed up.
To see a list of devices whose configs are not backed up, click the yellow slice or one of the boxes.
In addition to scheduled jobs, you can manually back up a config.
