Documentation forNetwork Configuration Manager
F5 device template behavior
When using device templates for F5 devices, consider the following behavior.
Device setup prerequisites
  • Set the Terminal Access user on the device to Advanced Shell. Do not use Traffic Management Shell (TMSH).
  • Verify the device can reach the NCM server for configuration transfers using SCP.
  • If you plan to upload binary user configuration set (UCS) files, be aware that the upload can take a long time. If the upload is timing out, increase the NCM timeout settings incrementally until the problem is resolved.
    1. Click Settings > All Settings.
    2. Under Product Specific Settings, choose CLI settings.
    3. Increase the following settings by a small amount:
      • Telnet/SSH Connection Timeout
      • Telnet/SSH Prompt Timeout
Template details
If you set up NCM to transfer configurations using SSH:
  • The template can download the current running config.
  • You cannot download the startup config.
  • You cannot upload the running or startup config.
If you set up NCM to transfer configurations using SCP:
  • The template can download and upload a text single configuration file (SCF) as a running config.
  • The template can download and upload a binary UCS as startup config.
  • You cannot upload the running config to startup, or startup to running config.
    Downloading or uploading configs using TFTP is not supported.
