Task Factory Secure Config
Important: The SecureConfig Task has no value within SSIS and doesn't perform any ETL processing. It can only be used with BIxPress.
Secure Config Task
| Task Icon | Task Description |
The SecureConfig Task allows users to encrypt/decrypt configuration files within BIxPress. This component does not have a custom editor and is configured from the properties window. |
